11sp Sram XD (Roam 30) Freehub walking out of rim engagement- Mtbr.com
    featherweight clydesdale
    Reputation: Fattirewilly's Avatar
    Dec 2001
    I hope my explanation makes sense....my rear hub has developed an issue where the cassette/freehub is walking out of the engagement area of the rear up, toward the frame. The small cog on the cassette moves all the way up to rear dropout area of the frame, stops up against the dropout, keeping the freehub engaged enough to ride. Shifting is totally screwed with the cassette a half gear off. Chain doesn't have room between the dropout to go down to smallest gear.
    I've re-installed the cassette and it walks off again in a couple miles. It just presses back on. Am I missing something? Or is it time to go back to Shimano.
    Charlottesville Area Mountain Bike Club
    www.cambc.org
    mtbpete
    Reputation: changingleaf's Avatar
    The end cap and the thru axle should be holding the freehub in place. The lockring holds the cassette in place. I can't think of anything else. See if any of these are missing or the wrong size.
    Bring the bike to the shop you bought it at.
    A picture might help. Let me know if you need any, I have a good ROAM 30 hanging in the garage.
    Reputation: Lone Rager's Avatar
    Dec 2013
    Yeah. I have a Roam 30 out in storage, so not quick/easy to look at. As I recall, the axle cap holds the freehub on. If the axle cap is missing, tightening the thru axle would pinch the dropouts together and cause it to bind. The axle cap is trapped by the cassette lock ring on the XD freehub.
    You say "go back to Shimano". Is this a splined freehub with a Shimano cassette or an XD free hub? It may be that you need a 1.8mm spacer behind the cassette if it's a splined freehub compatible with road 11 speed, or and XDR compatible freehub with a mountain cassette.
    Do the math.
  1. Replies: 8
    Last Post: 07-29-2019, 10:37 PM
  2. Sram GX shifter 11sp with Shimano XT 11sp derailleur
    By DirtDiggler in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-03-2018, 07:40 AM
  3. Sram 11sp XD driver
    By Mark194 in forum Singlespeed
    Last Post: 07-02-2018, 09:38 AM
  4. The walking dead/fear the walking dead
    By darth biker in forum Off Camber (off topic)
    Last Post: 03-29-2016, 07:44 PM
  5. SRAM 11sp XD Driver
    By New Guy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-16-2015, 06:24 PM
Members who have read this thread: 22
