2010 Ibis Mojo Review- Mtbr.com
Results 1 to 3 of 3
    Check it out
    Summary
    The Ibis Mojo is an efficient nimble climber. On descents it is very capable offering a firmer suspension with the frame easily deflected in rough terrain or around high speed corners. This bike would be ideal where climbing efficiencies are preferred over descending capabilities. Interestingly Ibis's new HD will be a bigger travel, slacker and stiffer brother of the Mojo and would undoubtedly be more biased to downhill performance.
    <object width="400" height="225"><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="https://vimeo.com/moogaloop.swf?clip_id=12473893&amp;server=vimeo.co m&amp;show_title=1&amp;show_byline=1&amp;show_port rait=0&amp;color=&amp;fullscreen=1" /><embed src="https://vimeo.com/moogaloop.swf?clip_id=12473893&amp;server=vimeo.co m&amp;show_title=1&amp;show_byline=1&amp;show_port rait=0&amp;color=&amp;fullscreen=1" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="400" height="225"></embed></object><p><a href="https://vimeo.com/12473893">2010 Ibis Mojo on the Sunshine Coast</a> from <a href="https://vimeo.com/leelau">Lee Lau</a> on <a href="https://vimeo.com">Vimeo</a>.</p>
    <object width="400" height="225"><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="https://vimeo.com/moogaloop.swf?clip_id=12126877&amp;server=vimeo.co m&amp;show_title=1&amp;show_byline=1&amp;show_port rait=0&amp;color=&amp;fullscreen=1" /><embed src="https://vimeo.com/moogaloop.swf?clip_id=12126877&amp;server=vimeo.co m&amp;show_title=1&amp;show_byline=1&amp;show_port rait=0&amp;color=&amp;fullscreen=1" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="400" height="225"></embed></object><p><a href="https://vimeo.com/12126877">2010 Ibis Mojo</a> from <a href="https://vimeo.com/leelau">Lee Lau</a> on <a href="https://vimeo.com">Vimeo</a>.</p>
    conjoinicorned
    Reputation: ferday's Avatar
    good write up. you and LeeL have quite a good thing going on right now!
    there are a ton of ibis' around calgary, i'll bet more per capita than anywhere else in canada!
    what would rainbow unicorn do?
    Reputation: Bilirubin's Avatar
    I would love to get another Mojo into Calgary ferday!
