150mm Marz 66 available?- Mtbr.com
    Hey all:
    Kooking for a Marz 66 RC2X 150mm fork - are they avaialble in Canada and if so where would you recommend I order one from. Want to put the fork on a Transition Preston but down here in the States can only get 170mm version, which would probably rake the bike out too much. Cheers!
    Have you considered the 66SL, or RCX2 for '06? I believe you can set the travel to 150, and still boost it up to 170 if needed.
    BL
    "Lightweight , durable , inexpensive
    Pick 2."
    Shying away from the 66SL because of the air - always preffered coil. The SL is getting great reviews - maybe I'll reconsider or just get a Z1. Anyone know, can I drop the 66RC2X height from 170 to 150mm?
    Formerly DMR For Life
    Reputation: Full Mountain's Avatar
    Mar 2005
    your best bet would be to contact a Norco dealer as they are the distributors up here...the only problem with that is that you would have to pick it up from the dealer
    DMR
