Results 1 to 46 of 46
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    Wren Stem 50mm 75gm
    I got some bad ideas in my head.
    Illuminati
    Reputation: scant's Avatar
    I'm using a wren stem on my XC bikes & its fine.
    Hardtail Steel Forever
    Reputation: jestep's Avatar
    I'm using an 80mm one. The gloss finish on them is amazing, I'm not typically a fan of gloss anno, but these are very nice. The lack of material for the threads on the steerer side is a bit scary, literally there's hardly anything there at all. They also use small M4 bolts, could probably save a few more grams with ti bolts since the ones that came with mine were just anodized aluminum.
    WTB: Med Bontrager Ti Lite, PM Me...
    Quote Originally Posted by jestep View Post
    Aluminum bolts should be lighter than ti bolts. You relly can't make a bolt smaller than it needs to be so lighter weaker aluminum wins over heavier stronger titanium. There are some places where stronger is better though.
    Latitude 61
    Illuminati
    I'm pretty certain, borderline postive that the bolts are steel
    Quote Originally Posted by scant View Post
    Mine are definitely black so I was assuming they were anodized aluminum. I'll check with a magnet when I get to the house today.
    A magnet wont work on stainless steel...
    Quote Originally Posted by lRaphl View Post
    I just checked and they are magnetic. It looks like they are painted, so painted carbon steel, I'm guessing?
    Dec 2008
    It's stupid and borderline suicidal to run aluminum bolts on the stem.
    Nov 2015
    Hi, Russ from Wren. I just saw the comments about the bolts used in the Wren stems. The Wren bolts are ChroMoly steel. We use ChroMoly for strength and a little weight savings. Biggest weight factor is the Torx bolt design. Torx bolts are smaller, lighter and stronger than comparable allen bolts. Our bolts are also lighter than Ti allen bolts. Remember to always use a Torx wrench on the bolts. Thanks for the interest in our stem!
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    One negative I found is that most multi-tools do not have T20 drivers on em, so if your stem loosens up, sometimes due to a real hard hit or whatever, you are out of luck or you need a different tool or an additional tool, which most likely earns you back the weight you saved. My Ritchey stem is also T20. Light, but probably not worth it for this reason.
    Nov 2015
    Excellent observation, Jayem, and one we realized quickly, so all of our stems are now T25. We have maybe 50 of the original spec of T20 out there. We have replaced some already. If anyone has an early Wren stem with T20, send us a copy of your receipt and we will send you a set of T25 bolts.
    Russ / Wren
    Reputation: MountainBored's Avatar
    Aug 2016
    This stem is going on my Xmas wish list!
    eri
    eri is offline
    Reputation: eri's Avatar
    Sep 2012
    Quote Originally Posted by RussJ View Post
    Russ / Wren
    Jeese man. What the heck is going on here?
    By responding with facts on this forum you are making other manufacturers look bad.
    You just talked me into ordering one, a 90mm unit, for my ss.
    Hmmm...that's weird. Both of my multi tools have both T20 and T25 on them. I have a Ritchey 260 too. Never been a problem with the T20's. You think they're bad...the earlier 260's had 3mm allen heads.
    Russ, do you guys have torque specs on your stems? And will that vary between the T20 and 25? I'll be grabbing one of your stems for my son's build for sure. They look awesome.
    Quote Originally Posted by jochribs View Post
    That's a rarity, I had multiple multi tools and no T20s, I looked for a while before I found one, but it's not what I'd call common, you are just lucky. In any event, it's cool that Wren is giving T25s to people (a common size).
    Reputation: santabooze's Avatar
    Oct 2010
    I just ordered 2 of these stems to replace my Turbine stems. 60mm of course
    Reputation: RS VR6's Avatar
    I have a 40mm in excellent condition if anybody is interested.
    Nov 2015
    Yes, the torque spec is 6Nm. Either T20 or T25. Thanks! Russ
    Ah, that's nice that they can handle a bit more torque. Most stems are calling for 5 at the max. You guys recommend going for a little lower, say 4.5 to 5, and seeing if that's sufficient?
    Nov 2015
    Just need to make sure your bars are tight without exceeding 6Nm. Thanks!
    Russ / Wren
    eri
    eri is offline
    Sep 2012
    Stem arrived Saturday. 90mm really is only 84 grams. Really smooth finish inside and out, whole thing is cold like metal but light like plastic and sculpted like liquid.
    I'm sorry to see the mighty chromag go, loved its graphics and interesting machined finish.
    The -6 degree drop gets the bars as low as brake lever clearance allows.
    What is surprising is how much I notice the 125 gram weight reduction. Used to be the back of the bike felt light, the front heavy, now it feels really balanced.
    My impressions: weight reduction feels like a big deal. Climbing I noticed the stem is not nearly as stiff as the chromag, but not noodley enough to matter. Mainly small sharp shocks are damped.
    I just bought one of these Wren stems. Iím kind of afraid of using it. How are they holding up over the long term?
    Illuminati
    2years old, no issues for me
    Oct 2015
    I ordered a 40mm and it's on the way. They assured me it's certified for DH use so that's good enough for me on my enduro bike.
    Aug 2016
    My 50mm stem is flawless after 1.5 years. I send it down lots of rocky trails and have crashed several times. No worries about the stem.
    eri
    eri is offline
    Sep 2012
    Update after almost 2 years: stem will no longer hold, headset loose after each ride. Cleaned fork steerer with acetone, etc, but stem just won't hold the headset at max recommended bolt torque. Stem doesn't move side to side but slides upwards during rough descents. Top and bottom edges and parts of the inside of the wren show worn paint. I put the chromag back on and it is solid as a rock. I might try harder to get it to hold - ideas?
    I'm 180 (but carry 10-15 lbs on rides), ride lots of steeps with roots and 1-2' steps, hardtail with 120mm fork.
    Reputation: phlegm's Avatar
    Quote Originally Posted by eri View Post
    Carbon paste? Might be just enough to allow it to hold at recommended torque.
    Jan 2009
    Are the bolts stretched out? It reads like they are no longer holding. The wren is built very weight weenie so I'd lean towards more xc than chunk with it.
    Coffee Drinker
    Reputation: Taildragger's Avatar
    Mar 2005
    Sounds like a 'star nut' issue, did you check that?
    Quote Originally Posted by Taildragger View Post
    That's a good point. I'm curious if the replacement chromag eventually loosens too? If so, it is that nut/expander. If not, something else.
    Jan 2009
    The star nut is for back up, its not intended to hold it together indefinitely. The stem still has to perform its function whether there's a star nut or not.
    Quote Originally Posted by thesmokingman View Post
    That's correct, but if the stem "grip" is marginal, the starnut/expander could also be failing. Either way you have a potentially dangerous issue.
    Jan 2009
    Quote Originally Posted by phlegm View Post
    Poster has swapped the failing stem so no issue. I'm just curious whether the bolts are stretched or the stem is fatigued. These wren stems are very weight weenie man, the stem bolts are stupid lightweight (M3) so I wouldn't be surprised if they gave up.
    eri
    eri is offline
    Sep 2012
    Well... chromag has lasted now for more than 7 hours of pounding and headset is still nice and tight.
    Starnut: like others have said it shouldn't be involved in holding stem in place, its for setting the bearing load.
    M3 Bolts: they are small, but they are steel and they laugh at that thin aluminum. I very much doubt the steel bolts are aging or stretched.
    The wren stem... to my eyes it looks 'fine' in the glare of the kitchen lights. The part that grips the steer tube is greatly hollowed out, the chromag has a full radius to grip the steer tube.
    When I tighten the wren onto the steer tube it sort of seemed to deform, to my eyes, in the dark garage.
    On both stems I have about 2mm of gap between top of stem and top of steer tube. Maybe this is the sort of stem that needs a spacer on top of the steer tube, so has a full steer tube to grip?
    Well... the wren is super light but I'm surprised how much more I like having a tight headset and solid feel at the bars. Just a small amount of play at the headset was making me consider upgrading to a float 34, but with a tight headset I'm now really happy with the 32.
    I'm sort of wondering if sanding steer tube or stem with a course grit sandpaper might improve the grip and get the stem working again, but now that I've rediscovered a stiff stem I have stopped really caring.
    Prolly for the best.
    I mentioned carbon paste above, which would achieve the same thing, however I've never had to use it on the steerer/stem interface.
    Apr 2018
    I ordered a stem from them and they're back to using T20 screws.
    Jan 2009
    Quote Originally Posted by RX93 View Post
    I was referring to the thread pitch, but yea still teeny sized bolts T20 included. From the bikeradar review, which apparently means they still have not improved the strength of the bolts.
    "To get right to the point, in my opinion T20 bolts just donít cut it. Fortunately, Wren seems to agree. Before I had even voiced my concerns, they had already made a running change to T25 Torx bolts. Problem solved. That should make it a lot easier to install and adjust, not to mention ensure that you have the right tool on your multi-tool."
    Oct 2015
    This. I wouldn't try and run such a weight weenie part without giving it the best chance it can to work, pretty sure no stem manufacturers would recommend running the stem proud of the top of the steerer tube. I always cut my steerers with plenty of extra height, if anything it helps for resale or potential frame upgrades.
    Carbon paste on the steerer and a little grease on the threads and under the bolt heads is also a good idea.
    Quote Originally Posted by GRPABT1 View Post
    FYI, the opposite combo of grease on the steerer and grit on the bolts is bad.
    Oct 2015
    Yes that would be ungood.
    I always use friction grease on stems and handlebars, no matter the material.
    Iíd double check the 2mm , I donít know what wren specs. (Ritchey specs 2mm) Possibly the top cap is bottoming out on the steerer inhibiting bearing load. Most top caps have a ďstepĒ that goes inside of the stem. Iíve had that problem, felt fine in the shop but no go on the trails.
    Just slap a thin spacer on top of the stem to test. Is the star nut deep enough? Iíve also failed on that account and the threads bottom out before full bearing load.
    Sometimes Rickety, not a turd
    Reputation: Just J's Avatar
    Feb 2005
    Mikeetheviking just showed me the Wren stems today, I had no idea about them but I'm intrigued and considering one for a new build!
    I can't help wondering though, do you think they're a good idea for a 235lbs rider?
    Oct 2015
    Quote Originally Posted by Just J View Post
    Until recently I was heavier than that and I've raced local enduros on my 40mm Wren stem. It's certified for DH after all.
    Feb 2005
    Exactly what I was wanting to hear, thank you!
  1. 75mm stem vs 50mm stem
    By Pedals On in forum 26er Bikes
    Last Post: 07-04-2016, 08:03 AM
  2. just went to 50mm stem and...
    By kneetowaist in forum All Mountain
    Last Post: 03-15-2016, 07:13 AM
  3. 50mm Stem
    By Michael Davies in forum All Mountain
    Last Post: 08-01-2014, 09:35 PM
  4. Need a 50mm stem
    By CanyunRider in forum California - Socal
    Last Post: 01-23-2013, 03:24 PM
  5. ASR 5 with 50mm stem
    By junkybum in forum Yeti
    Last Post: 02-25-2012, 06:28 PM
Members who have read this thread: 153
