Why get rid of the compact crank design?- Mtbr.com
Results 1 to 15 of 15
    rad to the power of sick
    Reputation: superlightracer's Avatar
    Hey all,
    Just a curiosity, why did bike companies get rid of the compact drive design? (5 bolt 94 bcd)
    From what ive seen, a CD has many more ring options especially for the middle ring. With the current 4bolt 104 mm the smallest middle ring you can run is a 30t...
    Insider ideas anyone?
    Some great sets for the trainer:
    https://www.mixcloud.com/djfeelgood/
    Reputation: Danke's Avatar
    Light makes right.
    Nov 2006
    i don't know but i was wondering the same thing.
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    4 bolt rings were stiffer is the argument I remember on rec.bicycles.tech which Keith Bontrager put forward in support of the 4-bolt cranks.
    I don't post to generate business for myself or make like I'm better than sliced bread
    On MTBR hiatus :(
    Quote Originally Posted by DeeEight
    If four bolt is stiffer, then three-bolt must be stiffest, right?
    <img src="https://www.booboodog.net/images/bent-surly-ss-ring.gif">
    speedub.nate
    MTBR Hiatus UFN
    SUBLIM8er
    Reputation: Axis II's Avatar
    Because new bolt patterns sell more cranksets- 'cause they are new!
    Every man has inside himself a parasitic being who is acting not at all to his advantage.
    William S. Burroughs
    If Raceface was to re-introduce the Turbine crank in optional square and ISIS with compact drive in the latest aluminum alloys they would sell very well IMO. Expect this to happen once almost everyone has "upgraded" to outboard bearings.
    Reputation: Some Guy's Avatar
    Mar 2005
    Strange, wonder why. Symetry perhaps.
    I love Pisgah
    Reputation: Duckman's Avatar
    I'd bet 4 bolt cranks are plain ol cheaper to mfg.
    I still have three 5 bolt(2 cmpt, 1 std) cranks in service on my best bikes atm. Not an outboard crank in the house tho. Prolly never will be. Something will simply change again before that happens.
    I love Pisgah
    Yea the outboard bearing bandwagon is about full now...I guess we need a change.
    I think the murder of the ISIS interface is a bit of a mistake.
    On MTBR hiatus :(
    Quote Originally Posted by Danke
    ISIS died of testicular cancer.
    speedub.nate
    MTBR Hiatus UFN
    Reputation: Joules's Avatar
    4-bolt is what Shimano wanted to sell. They offer all the chainring sizes you'd ever want, provided you don't want anything but 22/32/44.
    damaged
    Reputation: npoak's Avatar
    This I agree with. I adore the ISIS system and have NEVER had a problem with any ISIS BB I've ridden...not the connection to the crank.
