What is "zero run-out"?- Mtbr.com
Results 1 to 8 of 8
    An MBAction article stated the following: "Stan's aluminum rotor holds zero run-out much better than a steel rotor"
    What is "zero run-out" and why is it beneficial?
    Carpe Noctem
    Dec 2005
    Runout is a way of describing deviation from straight or flat. basically they're saying it doesn't warp as easily, be it from force or heat.
    Off season? What off season?
    Dec 2005
    I read that article as well. He said his RacerX is 21.5 lbs??? That doesn't seem possible with the components he's got on it. Anyone else find that a little far-fetched?
    Reputation: CulBaire's Avatar
    Any chance of printing the artical?
    I think a 21.5lbs Racer-X is posable, but there would have to be some awefully stupid parts on it and wouldn't really be all that ridable.
    Cul is a regretted trademark of the CulBaire Co'op Pty Ltd, as are his random ramblings and associated bullshit.
    Driven by watts inside
    Reputation: - Jeremy -'s Avatar
    It's right here: http://www.mbaction.com/detail.asp?id=1670
    I am also very dubious of the 21.5 lb claim. Must be an XS frame
    He's got a F80/100X, Maxm seatpost, Maxm riser bar, XTR cranks, etc. Nothing light enough to get to 21.5 lbs, IMO. Wonder what kind of seat he's running.
    - Jeremy -
    Doubt very much that bike is 21.5lbs, not with that setup- obviously they have a dodgy scale for weighing parts- or they are going off "claimed" weights.
    The frame does look abit small for the rider. I would sya a small- as in the artical it mentions 4" of travel- Titus do not make an X-Small in the 100mm travel Racer-X.
    Also on my weight listing- using a medium frame, you need some pretty crazy weight parts even after the Stans wheelset and rotors are factored in to get the bike below 22.lbs.
    Quote Originally Posted by CulBaire
    I suspect a typo.....should have been 25.1
    Dec 2005
    Nope, the article says 21.5lbs with Kenda Karmas and 20.7lbs with Kenda Kozmik Lites for cross races. I'm guessing it weighs about 23.5 - 24lbs minimum.
