Weight difference XT 770, 780 and XTR 985 disc brakes- Mtbr.com
Results 1 to 11 of 11
    I'm thinking of upgrading my current XT 770 disc brakes.
    Mainly because with the position of the brain on my Stumpjumper Fsr Expert 2008, I have to run a 180 mm disc in the back.
    I was now wondering what the weight difference would be between my current XT 770 brakes, the new 780 brakes and the XTR 985 brakes.
    Anyone knows their weights without discs?
    If possible without mounting bolts, brake pads etc ...
    ups and downs
    XTR F&R brakes. The orange spacer is 4gms.
    Attached Thumbnails Attached Thumbnails Weight difference XT 770, 780 and XTR 985 disc brakes-2010_1210new0003.jpg
    rockyuphill do you know the weight of that plastic red part?
    edit: saw it, thanks!
    In meantime I also found the weight of the XT 770.
    Now still the weight for the new 780 and 988 trail brakes
    Shimano XTR Trail (not mine)
    2011 Shimano XTR trail BR-M985 front disc brake 780mm hose with resin pads - Sick Lines Gallery
    I imagine the new XT brake will fall right in the middle of the XTR trail brakes and the older XT brakes.
    Reputation: amillmtb's Avatar
    Jun 2005
    Quote Originally Posted by Trevorken View Post
    New, uncut hoses...
    Front (180mm):
    Rear (160mm):
    ups and downs
    http://forums.mtbr.com/8317964-post45.html
    268 gms for new XT front brake w/o adapters, rotor or mounting hardware, so about 55gms heavier than the XTR race brake
    Thanks for the help.
    I think that I better can stick to my old brakes a bit longer and think a bit about how much I want to spend for these small losses in weight.
    Reputation: bikerboyj17's Avatar
    Quote Originally Posted by rockyuphill View Post
    Rocky are those brakes uncut?
    ups and downs
    Yep, fresh out of the box. Cut them after they were installed. Saved about 4gms in brake hose.
    Thanks. Could you give a little review of the brakes?
    If possible could you compare to them the older (pre 208) Magura Marta SL's? I know it's a long shot that you've used both brakes but I figure its worth a try.
  1. Real weight advantage of V-brakes over Disc Brakes
    By sergio_pt in forum Weight Weenies
    Last Post: 11-26-2009, 07:50 PM
  2. Difference between Magura disc brakes
    By Psycho Marco in forum Brake Time
    Last Post: 06-05-2009, 04:29 PM
  3. Weight difference between LX,XT,XTR CL disc??
    By gticlay in forum Brake Time
    Last Post: 01-26-2009, 01:37 PM
  4. Handling difference between rim and disc brakes?
    By sovietspyguy in forum Urban/DJ/Park
    Last Post: 11-02-2006, 04:49 PM
  5. Difference between disc and v-brakes..?
    By garym221987 in forum Brake Time
    Last Post: 01-04-2006, 06:41 AM
