Trimming some more weight- Mtbr.com
Results 1 to 5 of 5
    I would like to get some more ideas on how to lighten up more my Airborne LS. Also does anyone have any experience on the Spicer titanium stem that I recently installed. Also I'm thinking of adding bar ends even though it will add more weight. Is there a good bar end that you can recommend. I saw the You Chase ti bar end and the SRP ti bar end, does anyone uses them or have used them? Thanks.
    Quote Originally Posted by mtberfrombothell
    Ditch the gears.
    Reputation: Bender's Avatar
    What kind of wheels & tires do you have? I would start there since it can make a good deal of difference. As far as barends I would go with KCNC. They are about half the weight of most and look quite good.
    Quote Originally Posted by Square Bladder
    Ditch the gears.
    And get rid of that boat anchor suspension fork while you're at it.
    Reputation: Hand/of/Midas's Avatar
    you can save at least 7 pounds by getting foam grips instead of those ourys.
