Token Ultralite expander cap for offroad usage?- Mtbr.com
Results 1 to 7 of 7
    Jun 2005
    Hi, does anyone know if this is strong enough to keep the headset tight on a mountain bike?
    http://cgi.ebay.com/TOKEN-ULTRA-Lite...QQcmdZViewItem
    If not, are there any other compression plug / expander caps that are any good? How about the Ring-Go-Star? Thanks!
    no, stick to a standard starnut/top cap/bolt - my starnut (cut in half) top cap (syntace) and bolt (aluminium) is 14 grams. that token expander was 13 with an aluminium bolt (stock is steel) and it didn't hold either the mtb or roadbike headset tight.
    Weight Weenie Shop Owner
    Reputation: DIRT BOY's Avatar
    Aug 2002
    Quote Originally Posted by retox
    They suck. You can have a new one that I have for $10!
    DIRT BOY
    Light-Bikes.com
    The Largest Site Dedicated to Light Weight Bikes and Sales
    Twitter: @lightbikes_com
    STS
    STS is offline
    Reputation: STS's Avatar
    The lightest solution is no expander, cap or spider.
    as it is the stem with enough force in his bolts what makes the work, not the cap
    I use the headset mounting tool to press the stem in his place before tightening the bolts,
    and that's all, 0g
    and I ride enduro/all mountain without problems
    Reputation: Bender's Avatar
    If you cant get it adjusted right try this http://www.pricepoint.com/detail/114...ock-System.htm
    and simply remove it when you have your stem tight.
    what happens if you have an off and your stem rotates around your steerer? you won't be carrying a headlock with you on the trails. this is one situation where the 14grams are worth carrying.
    Hack Racer
    Reputation: Cheers!'s Avatar
    Get a Tune Gum Gum
