Tires...wire-bead vs Kevlar- Mtbr.com
Results 1 to 5 of 5
    Pisgah-Pale-Alien
    Reputation: FatTireGoose's Avatar
    So as I considered shaving weight off my new 29er, that came with wire-bead Schwalbe Rocket Rons, one tried and true method was always going foldable on the skins. Without a whole lotta research I bought some Kenda Slant Sixs, assuming they would be much lighter being Kevlar. Not true, they are actually heavier. Old assumptions are no longer safe.
    ups and downs
    That's a reasonable assumption for the same brand, make and model of tire, on a 26" tire the folding bead will likely be 100gms lighter, and likely 120gms on a 29" tire, so your folding Slant Six is likely 120gms lighter than a wire bead Slant Six in the same size and compound.
    When you look at the huge range of tire weights you definitely can't make that assumption across different brands and models.
    Quote Originally Posted by FatTireGoose View Post
    Pretty much sums up why most people can't navigate through life either.
    Apr 2005
    not to mention kenda tires pretty much suck, they are bottom of the barrel.
    Reputation: loggerhead's Avatar
    Just by looking at the tread (or how much of it) on a tire will help you out on whether it is a light tire plus sidewall thicknesses and size.
  1. Kevlar Folding vs Wire Bead
    By jmcgonig in forum Wheels and Tires
    Last Post: 04-25-2006, 06:45 AM
  2. Kevlar or wire bead.....
    By p0Ke'm@n in forum Wheels and Tires
    Last Post: 01-11-2005, 08:09 PM
  3. Wire bead vs. Kevlar Bead tires?
    By cdloental78 in forum Beginner's Corner
    Last Post: 08-04-2004, 11:13 PM
  4. Stan's with wire bead or kevlar only?
    By ryan123 in forum Wheels and Tires
    Last Post: 08-01-2004, 11:44 AM
  5. Wire or Kevlar bead?
    By CBar in forum Wheels and Tires
    Last Post: 07-14-2004, 08:44 PM
