Ti brake studs on a Ti frame?- Mtbr.com
Results 1 to 9 of 9
    New question here. Ti brake studs on a Ti frame?
    Is it ok to use Ti brake studs on a Ti frame? I don't want to use aluminum brake studs. Will Ti sieze up or has anyone had success with this?
    Thanks very much,
    Trevor
    Ti Prep
    Quote Originally Posted by tmaybee
    Thanks very much,
    Trevor
    Yep, absolutely fine provided you use an anti-galling compound such as Finish Line Ti Prep. Ti to Ti will almost definitely seize if you don't apply anything... and you still run a risk with regular grease.
    The surface of titanium (seen under a microscope) is very rough, so when two titanium components are tightened these tiny imperfections can cause them to lock together. Anti-galling compound resolves this issue.
    Quote Originally Posted by manitou916
    cool. Thanks very much for the info.
    Cheers,
    Trevor
    New question here. hmm...
    Does anyone know how the anti-galling compound works? Does it fill in the holes?
    Chris
    Quote Originally Posted by ctxcrossx
    Chris - that is absolutely correct. Anti-galling compound fills the microscopic flaws in metals with microscopic bearing particles which then act as a barrier between the two surfaces.
    How to apply this compound?
    How are you supposed to apply this compound? For example, do you put a small streak on like locktite, or do you carefully coat all threads? Also, do you coat both components (i.e. bolt and receiving threads)? Finally do you apply it liberally or do you clean out excess with a rag. So many questions, so little time.
    PS - I suppose you can't use locktite with this compound, true?
    Rob.
    Quote Originally Posted by Rocky
    Rob.
    Personal experience is that I prefer to be safe than sorry - apply a relatively liberal coating to all the threads and wipe off the excess.
    Loctite - That's actually a good question because for i.e. BB cups you want them to stay tight but don't want them to seize. Have to be honest and say I've never felt the need to use loctite on a bike... but if the threads are covered with an anti-galling compound then the loctite won't have anything to hang on to. I would go with one of the other - depending on the application.
    Reputation: CactusHead's Avatar
    Where can you get Aluminium and Ti Brake post?
    Can anyone tell me where you can get Ti brake posts? How about Aluminium? I've seen people write about getting AL post but don't know where they can be had or the reliability of AL in a brake post application. Any help would be appreciated.
    Quote Originally Posted by CactusHead
    Hi CactusHead. I can get you Ti brake studs. Please contact me off-board at jimvaughn(AT)hotmail.com ....just replace the (AT) with at
    The best way to find what size you need is to remove the stud from your frame and go to a hardware store and try to thread some nuts onto it. Most studs are M10, but there are several different thread pitches, M10 x 1 and M10 x 1.25 are most common.
    You can get Al brake studs from extralite and I think DirtBoy sells them.
    Cheers,
    Trevor
  1. Replies: 13
    Last Post: 01-30-2010, 11:53 PM
  2. Brake choice on an Eastern Woods Research frame Build up
    By Eastcoaster in forum Vintage, Retro, Classic
    Last Post: 03-04-2005, 01:42 PM
  3. Source for Ti Canti Studs?
    By kenais in forum Weight Weenies
    Last Post: 02-26-2004, 06:35 AM
  4. What size are Hayes brake bolts? Ti Question
    By FLYBYU in forum Weight Weenies
    Last Post: 02-24-2004, 10:01 PM
  5. Removing brake bosses: void frame warranty?
    By SilverStar in forum General Discussion
    Last Post: 02-17-2004, 08:05 PM
