Are these good components to loose 4lbs on the cheap?- Mtbr.com
Results 1 to 7 of 7
    I'm trying to get my 30.5 lb GT Sensor down to around 25-26 lbs for around $600. Are these good choices so far? Thanks! I'm new to this, so some of these weight savings estimates could be off, but most are from weights I found on the internet.
    component cost grams weight savings
    Ritchey WCS Ergo $6.99 36 120g
    Easton EA50 31.8 $9.99 160 90g
    Truvativ T20 Bars $20.00 160 120g
    Road Saddle $0.00 220 145g
    Easton EA 70 post $20.00 260 150g
    Total Total Total
    $56.98 836 625g
    Eggbeater pedals $30.00 256 50g
    DT Swiss wheels 350 1614 410g
    Vulpine TCS Tires $80 1020 649g
    Total Total Total
    $460 2890 1109g
    West Chester, PA
    From a dollars per gram perspective almost everything makes sense. Except the tires. Is it really worth going with a semi-slick tire to save the grams ? You should be able to find some more capable tires that are 600-650g each.
    +1
    i went for maximum weight savings with race king supersonics (430g on their site) and am now shopping for advice on an alternative tire.
    light weight with no traction = pushing a lighter bike up climbs
    Thanks, good advice. Not sure what the conditions will be like this spring, so it's probably be a better idea to go with a more versatile tire..
    Feb 2010
    Quote Originally Posted by vqdriver View Post
    +1
    You need the RK 2.2's - 460g. Great rear tyre - supreme amounts of traction.
    Dec 2008
    Quote Originally Posted by TigWorld View Post
    X2
    ~Reformed Mechanic~
    Reputation: Ace5high's Avatar
    Jan 2011
    Quote Originally Posted by 92gli View Post
    I agree about the tires, ditch these and get yourself some IKON or Aspens
  1. Cheap Shimano components in Japan?
    By mark439 in forum Asia + Philippines
    Last Post: 11-30-2010, 10:07 PM
  2. Cheap, colored components?
    By rvsteele in forum Beginner's Corner
    Last Post: 06-26-2009, 09:38 PM
  3. is there anywhere in amsterdam i can buy bicycle components cheap?
    By frenchbulldog in forum Beginner's Corner
    Last Post: 05-25-2009, 07:01 PM
  4. Cheap components at Transition Bikes
    By formulate in forum Where are the Best Deals?
    Last Post: 12-19-2008, 03:09 PM
  5. New cheap components vs old good ones
    By ilikemy944 in forum Beginner's Corner
    Last Post: 08-17-2006, 08:58 PM
