Is there such thing as a ti seatpost clamp?- Mtbr.com
Results 1 to 13 of 13
    Feb 2005
    I really fancy one for my IF ti deluxe singlespeed instead of the standard black one supplied.Ive tried a search and nothing came back so i thought i would post up a request.
    Is there a manufacturer of a ti seatpost clamp? Preferably bolt through?
    Thanks.
    Feb 2005
    Excellent snowdrifter.Thankyou very much.
    Hack Racer
    Reputation: Cheers!'s Avatar
    what size do you need? Since you posted on the weight weenie forum you might as well get the lightest Ti clamp
    http://cgi.ebay.com/OMNI-Racer-Ti-Se...742.m153.l1262
    Feb 2005
    Im not sure what size i need.Ive emailed IF asking about this,just awaiting a reply.All i know is its a 27.2 seatpost diameter.Then just to choose which clamp to get.
    Thanks everybody for all the reply's.
    the train keeps rollin
    Reputation: snowdrifter's Avatar
    I wouldn't get one too skimpy, or your seatpost will slip.
    27.2 seatpost = 31.8 seat collar 99% of the time.
    beaver hunt
    I read somewhere Woodman had one called the Deathgrip SLTi. Might be worth checking out.
    Hack Racer
    Quote Originally Posted by frontierwolf
    That is not a Ti seat post binder.
    Reputation: Ultra Magnus's Avatar
    Quote Originally Posted by Cheers!
    I was falling in love until I saw the price.
    BM
    "I've come to believe that common sense is not that common" - Matt Timmerman
    Jun 2005
    I have the omni-racer Ti clamp, I had to switch the Ti bolt to a steel one so I could get it tight enough that my post didn't slip :/
    Kind of defeated the object.
    ups and downs
    Jeez some of those are getting down to the point where you could just use a couple of wraps of Ti safety wire around the seat tube.
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    Why bother with the clamp... why not just drill a hole thru the seattube and seatpost from one side to the other the exact same diameter as a seatpost bolt, then bolt the seatpost it place.
    One of these days the brands reallize its stronger & lighter to go back to welded/brazed mounts for the seatpost bolt/qr than to use a seperate clamp & bolt/qr.
    I don't post to generate business for myself or make like I'm better than sliced bread
