strong and light stem for 200 lb XC rider?- Mtbr.com
Results 1 to 2 of 2
    I'm curious as to what stem you all would recommend for a 200 lb rider looking to get into XC racing. I know of a couple of light stems like the Ritchey WCS and the FSA . Is there anything else out there that offers a good strength to weight ratio? Currently on a Thompson (which I don't dislike) but I'm just exploring other options for my new bike. I don't ride too agressively (usually try to roll stuff rather that launch it). Thanks for the help.
    Just passing through....
    Reputation: DaFireMedic's Avatar
    Quote Originally Posted by pigpen
    Any of these stems would work:
    http://forums.mtbr.com/showthread.ph...highlight=stem
    I'm 185 lbs and I use the Syntace F99 (103 grams with Ti bolts, about $90 with the Ti) and the Pazzaz stem (147 grams with steel bolts, $16) on my bikes, both at 120 mm. Both would be fine for a 200+ lbs rider and will serve you well, it just depends on your budget.
    If you want to play with electricity, more power to ya......
  1. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  2. New to the scene. Looking for STRONG rims for a P1 rider ( 245lbs)
    By thoughtless0ne in forum Wheels and Tires
    Last Post: 06-08-2004, 03:07 PM
  3. Mavic XC 717 -- strong enough?
    By Jwiffle in forum Wheels and Tires
    Last Post: 04-01-2004, 08:02 PM
  4. Wheel building gurus - what spokes for a 215lb XC rider?
    By Smytty in forum Wheels and Tires
    Last Post: 03-19-2004, 01:08 PM
