Soecialized S-Works Cranks ?s- Mtbr.com
    Specialized S-Works Cranks ?s
    I am considering this crank for my next build and am in need of some info:
    What is the Q factor of this crank?
    Is there a 74-110, double, 5 bolt spider available? I really prefer the 74-110 standard for ring choices (thanks Rotor!) although I could the Sram 38/24 pair, I would rather choose my own, standard bcd rings.
    Finally: what's the verdict on reliability. Considering all the Specialized road pros that have used it, I figure this crank must be pretty reliable these days.
    Dec 2008
    The Q factor on my 2011 MTB S-Works cranks is 167mm.
    Yes on the 110 five bolt spider Lightning Carbon Cranks
    I've got a season on mine & they've been perfect - no issues.One nice thing about these is they don't use a carbon spider, which is where alot of carbon cranks fail.These are spec on all S-Works MTB.I suggest running the rubber boots for the end of the cranks.
    Thanks...
    for the info. 167 mm is not too bad, just 4 mm wider than Rotors, I can live with that. I will check the Lightning site for spiders, I did not see the 110/74 double last time I was there (just 110 only compact road).
    Reputation: DavidR1's Avatar
    Lightning makes these for SpecEd right?
    I thought I remember a thread about this at one point. You may be able to check with them as they may offer more options.
    CyclingCentralVa.org
  1. S works cranks - where to buy?
    By singletracknick in forum Specialized
    Last Post: 06-19-2011, 07:28 PM
  2. Cranks for your 2010 s-works - Lightning Cranks
    By diver160651 in forum Specialized
    Last Post: 04-24-2010, 07:05 AM
  3. Anyone have S-Works MTB cranks?
    By scooter916 in forum Specialized
    Last Post: 06-07-2009, 06:51 PM
  4. Q-factor for S-works cranks?
    By joe_wiley in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-08-2009, 07:49 AM
  5. Any one not want to run S-Works cranks?
    Last Post: 02-07-2009, 09:32 AM
