Sid F& R Shock question- Mtbr.com
Results 1 to 2 of 2
    Does it matter if you put in air in the neg. or pos. first. It seems i heard you must put the air in the pos. first then the neg. ?? I'm using Sid on both front and rear (front Sid is a Race) Thanks
    I'm not sure if it matters... But why go against their directives? Just do as they say and all will be fine!
    Luego!
    CODMAN MCM#101
