Road derailleurs on mtb- Mtbr.com
Results 1 to 9 of 9
    Hi out there
    My XT frontderailleur is kinda heavy (about 155gram), so i thought that a roadderailleur could fit?
    Size is 34,9 and uses toppull, rings are 44/32..
    Looking at campagnolo, i find some sub 100gram units, but do they fit?
    I run SRAM X.0 twisters ?
    Thx in advance
    Reputation: nino's Avatar
    problem!
    Quote Originally Posted by Zeus !
    Hi out there
    Thx in advance
    you have no luck: road derailleurs are all bottom pull.
    Aug 2005
    do you got a frame with buttompull it's no problems.
    Ha ha
    I didnt know that :-)
    So, got to get XTR then, perhaps with alubolts.
    Thanx!
    All 26.5" all the time!
    Reputation: Zanetti's Avatar
    There was an adapter that shimano made available around '90-'95 that allowed a bottom pull FD to be operated from above. It required a cable anchor on the frame around the BB/chainstay area.
    correct BUT....
    Quote Originally Posted by Zanetti
    hey - his main goal was to loose weight...such an adapter might weigh more than his current derailleur
    The adapter probably weighed less than five grams.....but finding one today would be tough. There was a period in time where top tube cable routing was becoming very trendy, but top pull F derailleurs weren't available. In that time, just about every MTB sold with top tube routing came with one of those adapters or a pulley setup.
    Reputation: kingfurby's Avatar
    Ha ha
    Thanx!
    I'm not sure how much new old-stock searching you want to do, but the xt front derailleur previous to this one only weighed about 125 grams. It was a decent derailleur other than the fact that the cage could bend a little under heavy shifting load.
    I really lucked out when I ordered a 34.9mm a few years ago, when I really needed a 31.8mm. It just sat around until I bought an NRS frame that took a 34.9 clamp. I think the old lightweight derailleurs were already quickly disappearing at that time, but I had my little mistake in my parts bin.
    Reputation: LyNx's Avatar
    Quote Originally Posted by kingfurby
    You didn't say if it was high or low mount, but either way JensonUSA has the old 123g XT M750-FD in 34.9 top-pull for just $19.50. Just got one myself and it's working great. Also if you're a fan of the older RD's the have them too.
