Olympic and which rimstrip?- Mtbr.com
Results 1 to 5 of 5
    I've just had a wheel rebuilt, swapped a 717 rim for an Olympic. I was running an Eclipse A126U strip/double sises tape with normal tires on the 717's, but now I'm unsure which strip (if any) I need. Can I use Stans yellow tape and an Eclipse valve, or just the old rimstrip (which fits ok) and do I have to use a Stans valve?
    Thanks.
    you shouldnīt need any rimstrip on that rim, most times it works great just with there yellow tape when using notubes rims. it shold work with eclipse valve, if you didnīt get any one with the rims.
    What It Be ?
    Reputation: ChrisJ's Avatar
    Aug 2005
    Yellow tape, Tubeless valve stem and some stan's goop and your ready to rock
    Thanks guys, I'll get some yellow tape and try the Eclipse valves...
    FIRENZE rulez !!
    Reputation: eliflap's Avatar
    but olympic rims requires dedicated valves , works only with it ...
    ..i red this on notube's site ...
    same for yellow tape : a specific model for olympic rim
    i used it but 3 years ago... not remeber well , sorry
