Nylon Top Cap- Mtbr.com
Results 1 to 6 of 6
Thread: Nylon Top Cap
    6x7=Dont Panic!
    Reputation: TheRedMantra's Avatar
    Nylon Top Cap
    When looking for a canti-V adapter I stumbled on this Dia Compe nylon top cap. Its only $1 and seeing as its made of nylon I figure its got to be light. Anyone weighed one before?
    http://www.amazon.com/dp/B000AO9V4M?...0&linkCode=asn
    http://www.biketoolsetc.com/index.cg...em_id=DC-ATC8A
    Herro prease
    MTB Withdrawal
    But the bling factor of a custom cap more than makes up the weight gain from a nylon one in perceived cyclist strength. Oh snap, this is WW, my bad.
    Completely off topic, please ignore.
    Reputation: Hand/of/Midas's Avatar
    you can remove the top cap AND bolt after you tighten your stems side bolts. alot of bmx kids do this actually.
    ups and downs
    8gms for the DiaCompe nylon top cap, about 1gm more than an aluminium one.
    Reputation: scooter916's Avatar
    purley custon ultra light is about 4g and the alloy bolt is about 3g
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    The Aheadsets always used to come standard with those nylon plastic top caps... its only recent years where they went to alloy top caps by default for even cheap aheadsets. But then not all alloy caps are created equal, some are heavier than others. The plastic ones didn't do anything better or worse, they just were thicker and weren't all glossy and colour annodized.
    Edit : I just weighed a dozen top caps... most of the alloy ones for 1 1/8 I weighed were 9g, a couple were 7g, one was 10g, and one was 12g. All the DiaCompe Nylon topcaps were 8g.
    I don't post to generate business for myself or make like I'm better than sliced bread
