Nylon nut for valve stem?- Mtbr.com
Results 1 to 9 of 9
    Dec 2005
    Idea! Nylon nut for valve stem?
    Hi guys,
    For those still using tubes, you know the valve nut on your tire valve? I.e. the part which secures the valve stem against the rim. Is it wise to replace it with a Nylon nut? It weighs a lot less. And any less rotational weight is a good thing. Any one know the specs?
    I guess I can always take an inner tube to a hardware store...
    Uh, "a lot less"? Really?
    From wiki, the Schrader valve spec says:
    METRIC: 7.7 mm OD, thread root diameter is 6.9mm x 0.794 mm pitch.
    IMPERIAL: 0.305" OD, thread root diameter 0.302" x 32 tpi (threads per inch)
    Dec 2005
    Heh, I meant in relative terms, not absolute
    Thanks, Ardent!
    STI member
    Reputation: FSRmatt's Avatar
    Quote Originally Posted by Ardent
    Isn't he talking about a Presta valve?
    The OD is ~5.75 mm fwiw.
    Edit: Calipers say 5.67mm.
    Reputation: upstateSC-rider's Avatar
    Cheaper and lighter still is no nut at all. This is the way I run my mt and road bikes without the first issue.
    Lou.
    Niner Jet 9 RDO, Scalpel 29, XTC 650b, 04 Stumpjumper FSR Pro, Trek Rigid SS - No suspension, no gears....no problem
    STI member
    Quote Originally Posted by upstateSC-rider
    Lou.
    You're dangerous. I'm leaving this thread before I get hurt.
    Dec 2005
    ... and if we just ...
    I just remembered that I always carry along 2 nuts when I ride
    (Sorry, it's a slow day. ho ho ho )
    Quote Originally Posted by FSRmatt
    We're talking about the little round, knurled nut, correct?
    Lou.
    I also leave the nut away...Haven't got any problem without it...I just don't use tubes...
