New frame needs some drive train advice- Mtbr.com
Results 1 to 5 of 5
    I put this in the Trek and the drive forums and no replies. I was hoping I could get some help from the WW group.
    I am not a WW but I plan on getting a Trek Elite 9.9 frame in the next two mths.
    At this time I will also upgrade my drive train.
    I will go 2 x 10 and I like Shimano shifting over Sram. However I like the 42x28 gearing much more than the 30x42 or the 28x40 gearing.
    How can I get a 42x28 gearing with shimano shifting? I was thinking about getting a rotor 3d crank but I donít like their Q rings. Would the extralite 42x28 rings work with rotor?
    Also could I get a RF next sl at 30x42 and then change out the 30 ring for a 28 ring?
    FSA makes a 42x27 crank. Their weights sort of suck compared to other cranks and I donít know if it would work with a BB90.
    Lastly this will be a BB90 set up so I would need the crank to work with that. How much of a tradeoff would I be making by getting a non shimano 42x28 set up? Meaning I love that gear ratio but I donít want to sacrifice too much front end shifting by mixing brands together.
    Thanks in advance for your help.
    ups and downs
    You could always buy a new 28T XTR chainring to build the 42-28, the rings will fit on the 985 42-30 cranks and the front derailleurs will cover a 40-44T big ring. The shift ramp clocking might not be exact.
    I see three options.
    1 - as above, buy a 30/42 M985 crankset and swapping the 30 tooth for a 28 tooth. Shift gates on the 42t big ring are placed to work with a 30 tooth so it won't be AS good. Being Shimano it'll still be fantastic.
    2 - just use a SRAM XX crankset with 28/42. One of the big positives to the XX group is the chainring stiffness and shift quality. Shimano chains work well with them so no issue there.
    3 - buy a 104/64bcd or 110/74bcd crankset such as Rotor 3D or Agilis and use Specialties TA chainrings instead of Rotor Q-rings. These are light and shift very well. The best of aftermarket chainrings.
    "Shift gates on the 42t big ring are placed to work with a 30 tooth so it won't be AS good"
    Dam I never even thought about that. Has anyone done this before and whats your experience? I really like the XTR 985 crank. Their version even though being aluminium is still very competitive in weight to carbon counter parts.
    I feel weird asking all these what if questions. But I need to, I don't have enough money to blow on different parts to get a feeling of how it feels and then choosing the one I like best.
    Two options. XTR 42x30 and getting a 28 spare chaining and switching. My front end shifting won't be as good.
    2nd option: running an XX crank with everything else XTR.
    Between the two what kinds of differences would I notice with front end shifting?
    I think that will end up making my mind up.
    Thanks again for the input.
    WW section rocks
    ups and downs
    Q factor on the XTR cranks should be a few millimetres narrower.
  1. Drive train problem, need your advice
    By spec d in forum General Discussion
    Last Post: 07-16-2011, 10:58 PM
  2. Replies: 4
    Last Post: 05-02-2010, 01:18 PM
  3. need advice on i-drive frame (cracked)
    By vrclowncar in forum GT
    Last Post: 02-03-2010, 09:08 PM
  4. Chain Suck, Drive Train Issues- Frame Damage
    By Free Spirit in forum Downhill - Freeride
    Last Post: 05-04-2006, 06:33 PM
  5. Replies: 44
    Last Post: 03-05-2006, 07:16 AM
