Results 1 to 7 of 7
    Ty
    Ty is offline
    Reputation: Ty's Avatar
    My new WW shifter !
    My new rear shifter, 39.4g !
Size:  302.4 KBName:  B.png
Size:  316.6 KBName:  C.png
    Trail Ninja
    Reputation: Varaxis's Avatar
    Friction shifter? Last time I used one of those, it was mounted on the bike's downtube. xD
    I'll take brainless shifting for another 60-80g. Functionality over weight scale porn. Can't be arsed to listen to my drivetrain for confirmation, especially in a riding group and when fatigued to the limit.
    We're all on the same ship, and it's sinking.
    Ty
    Ty is offline
    Quote Originally Posted by Varaxis View Post
    Friction shifter?
    Indexed (9 speed)
    I actually had this under 30g at one point (28.2g), I molded and cast the lever part and some of the internals in a two part resin, it worked just fine, but I preferred the solid feel of metal !
    Thanks for sharing.
    Trail Ninja
    Quote Originally Posted by Ty View Post
    Indexed (9 speed)
    Ok, you've piqued my attention. Method to release cable? Cable pull rate per click? Can I see the guts?
    Looked for others like it. This is all I found. Honestly couldn't imagine anything fitting in there besides a bushing.
    Update: Oh derp. Discovered that some versions of these were simply friction shifters with detents. xD
    Ty
    Ty is offline
    Not 100% sure what you mean, it's a standard cable system where you thread the cable through the back of the lever.
    It's 9 speed, driving a Dura Ace RD7700.
    Can I see the guts?
    Not easily, I've bonded the central core thing whatever you call it (the central column that the lever arm rotates on) to the mounting bracket, so it's not coming off anytime soon !
    Ty
    Ty is offline
    It's a thick (but hollow) steel ring (at least I think it's steel) with raised edges, with indents around the circumference.
    Trail Ninja
    My bad. I was being narrow-minded and comparing it to rapidfire or double-tap, as opposed to gripshift or bar-end shifters. Essentially adding detents to a friction shifter.
    I've found exploded diagram examples and pics of disassembled examples already:
  1. N00b shifter question: depressing the right-hand shifter all the way
    By Grease Monk3y in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-19-2013, 05:52 AM
  2. N00b shifter question: pressing the right-hand shifter all the way
    Last Post: 08-17-2013, 01:26 PM
  3. Replies: 1
    Last Post: 02-27-2013, 12:04 PM
  4. XT 770 rear shifter vs. XTR 980 rear shifter
    By Slow Danger in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-05-2012, 10:01 AM
  5. XTR M970 3 ring shifter work as a 2 ring shifter?
    By Hawgzilla in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-09-2011, 10:52 AM
