Lighter tires for Ibis Ripmo's second wheelset- Mtbr.com
Results 1 to 19 of 19
    Sep 2016
    Posted here because I've read similar threads elsewhere that drift away from weight. I think the OCD in this room might keep things focused
    I newly own an Ibis Ripmo, which I really love. I'd like it to be reasonably light, but an not obsessively concerned. For instance I got the heavier blue paint option. That way strangers can tell it's a Ripmo from a distance and feel superior to the yuppie kook walking the gnarly bit. 5 ounces to me is worth spreading that sort of joy.
    I am though in the process of building up a second wheelset - Lightbicycle 33mm inner carbon 29er, ~1680 grams. So ~200 grams lighter than the stock Alloy S35 wheelset.
    The stock tires are Assegai 2.5's in the EXO+ casing, and they are freakin' awesome angry traction pigs. 1125g claimed weight per tire. I'm happy enough to pedal them uphill when I'm trying to survive ugly unsanctioned slimy rooty steeps with guys who are much better than me at riding them.
    But also I want a lighter set of wheels for riding on blue trails. The carbon wheels are a start, but I feel like I could REALLY save a lot of weight by mounting tires in the 750-850 gram range. I mean if I can deal with tires averaging about 800 grams each, my "trail" wheelset would be 850 grams lighter than my "enduro" wheelset. 2lbs less, and off the wheels. I could go for that.
    I want the lighter tires to be knobbier than Maxxis Icons. I like Rekons and have rode them extensively, but maybe prefer a front tire with a little more aggressive edge dig. Fast rolling in the rear is important. And would definitely like a rear tire that can to some extent protect the rear rim from getting smashed.
    At the moment I'm most strongly considering Nobby Nik 2.35 (~800g) rear and Forekaster 2.35 (735g) front. I will be riding a lot of well build trails on these tires, in PNW conditions. I do have some concern that the sideknobs on the forekaster will fold too easily on berms etc. I weigh 205lbs, XL bike. And these tires will see some terrain, not just scooting around the smooth stuff.
    What do you say about this combo? Can you offer better alternatives? I wouldn't mind another 50-100g more for a little burlier, chunkier, more protective. Up to 2.6 fits my frame.
    Reputation: phlegm's Avatar
    Unsure how up to date this is, but there's a database of 29er tire weights that may give you some ideas:
    https://forums.mtbr.com/29er-bikes/2...se-577466.html
    I was looking myself at the Schwalbe Fat Albert, which has unique front and rear tire versions. They rate them slightly better traction than their Nobby Nics, and they're 2.35, claimed 780g. Haven't tried them myself though.
    Feb 2013
    Last season, also PNW, I had a Ardent skinwall 29x2.4 front, it was quite a bit under 800g, closer to 700g iirc, the non-tubeless-ready skinwall Ardent worked perfect on older stans rims tubeless. Joey at Indigenous Wheel recommended that to me, he ran that tire front and rear tubeless last season, also zero issues (my new xc rims from him are 295 and 300g). Also to consider, my 29x.2.35 Ardent race EXO TR is 785g, I raced that in some mud and it was pretty decent, - I'm going with forekasters for the upcoming early series on that bike which are in the low 600s in 29x2.2.
    skidding is the signature of the novice; learn how to use your brakes.
    Oct 2015
    If trails are dry. I'd do the Dissecor front Forkaster rear.
    Sep 2016
    Thanks gents (and or ladies), all of this is very helpful.
    Pursuing the first response's tip, I found the following database, which lists thousands of MTB parts that can be sorted by weight. The website is a little kludgy, but really helpful to be able to scroll a list of all 29er all mountain tires in my desired weight range, provisionally rated in a bunch of different categories.
    Security certificate not up to date, but doesn't seem likely that whomever went to all this trouble did so as an elaborate ruse.
    https://www.dirtshed.com/gear/browse
    I am trying Maxxis DHRIIs 2.3 front, 2.4 rear. Those are in your weight range and have plenty of knob. Still looking for the holy grail of tough, light and grippy. Oh ... probably one of those "pick 2" situations Right now I'm a bit nervous about the front ... used to seeing my Assegai or DHF 2.5 up there, but I think the DHR2 actually grips pretty well even though it doesn't look as big.
    Reputation: JoePAz's Avatar
    May 2012
    I have a Ripmo and run the factory optional set up. 2.6 Hans Dampf Front and 2.6 Nobby Nic rear. That works well for my terrain and use. When they wear down I will probably go with XR4 2.6 however. My XC bike use Ikon or XR2 and I really have no desire to got that light on the Ripmo. What I gain in pedaling I risk by throwing the bike around on the rocks since the suspension works so well. You could try a Forekaster front and Rekon rear. I used that setup on a 5010 with 2.6 on 35mm wheels. It was my burly bike at the time and they survived some good chunk. This set up was much less draggy than 2.4 High Roller F/2.35 Hans Dampf R that was on the bike before. The wider tire make up for less knobs when it came to grip.
    Joe
    '18 Specialized Epic 29", 19' Vassago Optimus Ti SS 29", '19 Ibis Ripmo, XC, AM, blah blah blah.. I just ride.
    Reputation: Davide's Avatar
    I am using a Rocket Ron 2.6 on the back of my Ibis HD3 and it works great. Front is Nobby Nic 2.6. The RR has an amazing amount of traction, and it feels faster than a NN 2.35 I used in the back. It is relatively light. On my scale the RR 2.6 is 725 vs the 740 of the NN 2.35, and the 920 of the NN 2.6.
    I do use a 2.35 NN/2.25 RR combo together with an ultra-light wheel set if I want a boost uphill. The smaller RR 2.25 works nicely, but you do feel the narrowness if you are on rocky terrain/roots, like probably any other 2.25 would ... it works but the 2.6 RR is more nicely footed, and the bike more balanced with 2.6/2.6.
    Reputation: PuddleDuck's Avatar
    Hi Hank,
    Here's some ideas for you
    Michelin Wild AM 2.35 ~800g
    Maxxis Dissector 2.4 ~880g (have a look at the PinkBike review that has just been posted)
    Vittoria Agarro ~980g
    Bontrager XR4 ~800g
    Bontrager SE4 (if you want a stiffer casing)
    HINT: if you want to search MTBR for e.g. the SE4, use this search string in google
    site:forums.mtbr.com SE4
    Sep 2016
    Thanks PuddleDuck!
    Reputation: MSU Alum's Avatar
    They don't make a Rocket Ron in a 29x2.6....if they did, I'd run them. My son ran 2.35 NoNi's on his Ripmo, locally and was blisteringly fast on them. They're light - I just weighed one with dried sealant in it at 780 grams.
    But, I'm 155 pounds and there are climbs that take over an hour where I'm just as fast on a 29x2.6 DHF front and 29x2.5 Aggressor rear, and that adds well over a pound to the weight of my NoNi's. I'm more impacted by hydration, diet, etc. At over 200 pounds, the added weight probably means even less.
    I tried 2.6 Rekons front and back and hated their almost complete lack of steering traction and climbing traction. People seem to like the 2.4's, though.
    Almost anything will roll better than a pair of Assegai's though!
    Oct 2019
    Bontrager XR4s are my go to tires. Gonna try the SE4 in the front and XR4 in the rear on my next set for my new Stumpjumper.
    I had bad luck with the XR4. One ride, nice slash in the tread. Couldn't trust it again, even if it was bad luck. Moved it to my wife's bike, it has been fine there. Thought hard about trying the SE4s as Trek had them on sale after T-giving.
    Thought this was interesting, could my 2.3 DHRII really be slower than the 2.5 Assegai?!?
    https://www.youtube.com/watch?v=je1UyJRYhIg
    food for thought.
    Oct 2019
    Quote Originally Posted by slcpunk View Post
    food for thought.
    Never had an issue with them after many yrs of using them and I've hit plenty of rocky trails on them. Of course extreme chunk could prove fatal to any tire with a lighter casing. If that is what you ride you need more protection. If it is not , I think it was exactly just a case of bad luck.Cheers!
    Reputation: Chuch's Avatar
    Jan 2013
    I'm running the Dissector Front (861g) and the Rekon 2.4 rear (about 825) and I am super happy with this combo.
    Santa Cruz HT2
    waiting for dissectors to become more widely available -- oh -- and for the price to come down. WTF. More than the Bontragers now. Still, definitely on the list. But seriously ... $80+ for a tire. No F-N way. I'm still having a hard time getting used to $50 a tire.
    Sep 2014
    Quote Originally Posted by Chuch View Post
    Did you weigh your Dissectors? I bought several 29 x 2.4's and they were all over 900 grams, 910-920 for all of them IIRC. Thought about sending some back but what the hay, it's only 50-60 grams.
    Ibis Ripmo V2
    Ibis Ripley V4
    Pivot Mach 4SL
    Pivot LES SS
    A road bike
    Jan 2013
    861 and 880 respectively. I still have one in the packaging hanging up that may be a tad heavier. You definitely got into a thick batch man.
    Santa Cruz HT2
    my ripmo is 28 pounds with 2.5 DHF and a 2.3 DHR in the back
    on my other bikes I run Nobby nic 2.35 in front and 2.3 ikon in the back. I run 20 psi at 165 pounds, The ikon skips around a lot but you get used to it.
    In the beginning i had trouble clearing rocky ledges, but over time you get better and will adjust to the tires.
  1. Ripmo lighter weight tire options
    By adagioca in forum Ibis
    Last Post: 12-02-2019, 12:35 PM
  2. Replies: 46
    Last Post: 02-10-2019, 08:43 AM
  3. Replies: 4
    Last Post: 01-02-2019, 02:46 PM
  4. Second Set of Wheels/Tires or a Second Bike?
    By CanyonEnduranceCross in forum Cyclocross
    Last Post: 02-25-2018, 11:33 AM
  5. Replies: 1
    Last Post: 03-12-2012, 04:55 PM
Members who have read this thread: 68
