Light Rear Derailleurs and light shifters?- Mtbr.com
Results 1 to 31 of 31
    Nov 2008
    At the moment i use XTR 970 shadow rear derailleurs on 179gr and XTR 970 shifters on 230gr.
    that's 409gr together.
    I want something lighter, what about X.0?
    What is the real weight of X.0 Rear-D and X.0 shifters?
    Reputation: Tiffster's Avatar
    My XO Rear derr with carbon pulleys is 177g a carbon outer cage brings that down to 170g
    My Xo triggers are 220g
    Reputation: nino's Avatar
    Quote Originally Posted by thue
    older Sram Plasma shifters: 153g
    Dura Ace rear derailleur: stock 181g / with some Aluminium Bolts+lightweight Pulleys: 164g....add carbon Plates: 153g
    yes - the DA also takes a 32 cassette!
    Nov 2008
    Not bad, Nino
    What about XTR 972 shadow with carbon pulleys (-10gr)=169gr
    What can i save of changing the small bolt who attach the wire into alu?
    Mabye i should change my XTR shifters into some light Sram Twister's?
    Something like Nino's Plasma....Can i find those in my LBS?
    Nov 2008
    For some months ago, I found a picture of a per of extreme light Sram twisters. I think the weight was 98gr or some thing like that. Do anybody know something about them?
    More carbon fiber please!
    You'll save roughly 2g changing the cable bolt over to aluminum I believe.
    grip-shifters....
    beware of those all plastic, old grip-shifters! action is all plastic.they change gears but the precision is all gone.i have some brandnew Sachs Quartz shifters sitting in a bix (120g the pair) but i would not want them on my bike.at this point you might go back to friction shifters and save even more weight.no good!
    Nov 2008
    Plasma are from around 1998.you will be a lucky man if you can locate them in a shop.your best chances are on ebay.
    And remember, the Plasmas are for Shimano derailleurs.
    Reputation: protocol_droid's Avatar
    I've got an m970 xtr nobu tuned derailleur in at 161 g with carbon cages and jockey wheels as another option for you.
    3po armorless, the first weight weenie.
    Nov 2008
    Quote Originally Posted by nino
    Hmm...is there a new modell of that plasma version?
    well...
    that's the X.O but those are heavier and for SRAM derailleurs only.same performance though.
    Jan
    Jan is offline
    Sram still have twist shifters for Shimano derailleurs. Sram Attack. About the same weight as X.0
    cmh
    cmh is offline
    So the new 7800 works with the 9spd stuff? I've got the 7700 on her bike right now, pretty good at 197g. (good enough for now, bigger dragons to slay on the bike before I go throwing money at it overhand)
    You're saying that the DA will clear a 32t cog?? even though it's only rated to 27? I guess the jockey pulley must be sitting on the cog at that point. Will have to try, although I don't think the chain is long enough right now...
    ** edit - just swapped wheels, yep, the DA 7700 rear clears a 32t, no problem. Guess you learn something new every day...
    Weight Weenie Addict!
    If you want to stick to XTR 972 shadow....you could put some carbon pulleys for a drop of 10-grams. For the shifters? I replaced both bolts with Schmolke Carbon bolts, but alloy is Ok for such small bolts...you are looking at another 6 grams. Besides that there's nothing else to do. Nobu (on eBay) once had some twister shifters that were modified (lighter), you may want to try him if these are Ok with you. He also have bits and pieces to make lightweight derailleurs.
    I am surprised no one removed the barrel ajuster on their derailleur, by drilling a 5mm hole. Save arround 6gr.
    Reputation: scooter916's Avatar
    what about paul thumbies with SRAM aero TT carbon bar-end shifters with a RED rear der? will Sram road Der clear a 32t???
    cmh
    cmh is offline
    Quote Originally Posted by Megaclocker
    Good point - should have a barrel adjuster on the shifter!
    Quote Originally Posted by cmh
    It would bring nino D/A to arround 148gr
    Hack Racer
    Reputation: Cheers!'s Avatar
    Paul Rear Derailleur. Circa 1995
    182 gram. The bling of the bling!
    Reputation: Broccoli's Avatar
    Indeed. I realized I never use that one to adjust, always just a click on the shifter.
    cmh
    cmh is offline
    Wow, and here I thought I needed to get a SRAM Red. Man, I wonder how light one of THOSE could go??
    I also wonder how low one can get the DA 7700. Bet if I looked at the roadie WW forums I could find out without too much trouble.
    Damn you all, making me re-evaluate parts which I thought I was "done" with.
    Reputation: millsm's Avatar
    Mar 2006
    120g rear derailleur
    If you want to go REAL light, check this out:
    http://www.competitivecyclist.com/mo...r-5760..1.html
    Don't think I can cough up $1200, though!
    Hey, I didn't see that rock there."
    Quote Originally Posted by millsm
    That's probably some of the worst grams saved per dollar spent ratio I have seen in a while.
    On the other hand, it costs $10 per gram - gold is about $25 per gram. Not the blingiest bling.
    Sram Red...
    easiest way to get a workable derailleur without having to tune with "homemade" parts is for sure the RED derailleur.i replaced just the pulles with lighter ones from Extralite to get it down to 132g!
    at the same time you could also go 10s with a lightweight 11-27 Ttanium cassette: 139g
    all you would need is the right-side 10s flatbar shifter from SRAM or a old-school friction shifter with a Paul Adapter.
    and don't forget to combine it with a Dura Ace front derailleur too!! those weigh just 78g including the 34,9mm clamp
    and for the hardcore you could just use 27/42 chainrings up front. my rings for example weigh just 70g (that's for the pair of them!)
    Keep Riding !!
    Reputation: AussieRider's Avatar
    Quote Originally Posted by Curmy
    FYI: The Sram Twist Shifters, X7, X9 & XO all weigh the same at 195gm (Sram listing not actual) so save some $$ and get the X7 at half the price!
    I agree cost per gram saved is crazy
    The link no longer works but I assume one of these:
    Just Ride !
    Quote Originally Posted by AussieRider
    Never liked twist shift, and I really like the latest XTR so far, with immediate and multiple release...
    cmh
    cmh is offline
    Well the good thing is she's just running a 1x9 (32t with a 11-27 modified Ultegra cassette) so no need for the FD. As for the RD, I've already considered the SRAM RED flatbar setup, but the thing I wasn't sure about is the doubletap shifter. She's pretty particular about her bike, hates Grip shifts, and I'm not sure how she would like that whole one lever to shift thing. I haven't had a chance to use any Doubletap shifters -- on anything -- so can't hazzard a guess. Then there's the whole RED RD costing $300+ issue...
    If the DuraAce 7800 rear mech works with the 9 speed mountain shifters and cassette, does the SRAM RED work with their 9spd shifters?
    +1 to that. They're awesome shifters. I'd have a difficult time giving them up. Maybe someone will brew up some magnesium or carbon mounts for the pods, or integrate pod mounts into superlight brake levers.
    What is the weight of stock shimano pulley ?
