light 130mm fork?- Mtbr.com
Results 1 to 6 of 6
    Aug 2005
    light 130mm fork?
    Anyone have an idea around what the lightest 130mm fork is?
    If you do something often enough it tends to define you.
    Reputation: minimusprime's Avatar
    I'm not quite sure what the lightest is... but I had a 2020 fox 34 factory that was incredibly light considering how good of a performer it was. The true light weight forks seem to be max 120 these days (sid ultimate). However the fox 34 factory, especially the 2020 fit 4 damper with the smaller damper shaft, are light as hell.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by butryon View Post
    Run a stepcast or RS SID 120 with a 10mm headset crown race spacer, unless you got 130mm rear travel, you don't *need* 130mm front travel.
    Thicc Member
    Reputation: TylerVernon's Avatar
    Nov 2019
    Reba RL 1650g
    2008 Lefty PBR Carbon 130. 1,344g.
    Thicc Member
    Nov 2019
    26er forks don't count
  1. Replies: 2
    Last Post: 12-02-2012, 06:35 PM
  2. 130mm fork on Kona Kikapu?
    By D.I.S.C.O in forum Kona
    Last Post: 02-16-2011, 09:24 AM
  3. Intense EX DC Light/ Edge Light/ System 4 Light?
    By Hardtails Are Better in forum Downhill - Freeride
    Last Post: 04-24-2008, 01:24 PM
  4. Fox 130mm coil vs. Fox float 130mm vs. manitou Black air 120mm??
    By ROG30Y in forum Shocks and Suspension
    Last Post: 01-07-2006, 01:34 PM
  5. Searching light, snappy hardtail frame for 130mm fork
    By geiranders in forum General Discussion
    Last Post: 04-05-2005, 05:46 AM
Members who have read this thread: 61
