How do you measure bolts?- Mtbr.com
    Reputation: bikerboyj17's Avatar
    I have a rusted out bolt on my seatpost and i want to replace it with a titanium one. Before I do that i need to know which size bolt to get. Help me out here guys.
    Jake
    Measure from under the head of the bolt where the thread starts to the end. That will give the length you need.
    Reputation: Irrenarzt's Avatar
    Bicycle bolts are typically described as the diameter size (i.e. M6) times the length (i.e. M6 x 15) all units in millimeters. You need to know the thread pitch as well which is typically the number of threads per unit millimeter (i.e 1.0 which is 1 thread per millimeter).
    Quote Originally Posted by Cline
    Unless its a flat head (countersunk) which then requires the entire length of the fastener to be measured for the correct value.
