Eclipse Tube Test Results- Mtbr.com
Results 1 to 16 of 16
    Aug 2005
    Since three days I'm trying to access the "Eclipse 56g...."-Thread with no success, the page is blank, I tried it on several PCs, So I made a new thread.
    The Tube has been tested in a german bike magazine., with actually pretty impressive results other than rolling resistance.
    Even though some say they don;t agree and it might be a typo.
    Anyway...if you care.
    Attached Thumbnails Attached Thumbnails Eclipse Tube Test Results-eclipse-test1.jpg
    I was thinking of giving the Eclipse tubes a try for the weight savings. That resistance table makes me think of just sticking with my tried and true Michelin latex tubes.
    ups and downs
    Do they indicate what the tire size and pressure were for the rolling resistance?
    Let's ride
    Reputation: rensho's Avatar
    Interesting results. How much are these?
    I laughed at the .75mm dicke spec.
    Reputation: karl711's Avatar
    I have had 3 of these tubes & all of them failed within 5 rides even with latex inside. The ride quality was very good but they were just too flimsy for my use. They deffinately were not worth the huge purchase cost.
    I have reverted to my tubeless set up & I can't see that changing anytime soon.
    pain & fear is natures way of telling you you're getting old!
    ups and downs
    They're 45 Euro each, which puts the weight saving in the $1/gm range. I have them on two bikes now and they've been good, no issues after the initial warranty replacement of two out of the first production run.
    http://www.jpracingbike1.com/Eclipse...-bbzaaaiBa.asp
    Reputation: Chase1996's Avatar
    Jun 2010
    Quote Originally Posted by Kris
    Where are you buying these tubes?
    Reputation: XgreygOOse's Avatar
    Quote Originally Posted by Chase1996
    You can get them from Robert at r2 Here Currently I am using them on both my bikes. I've had a few punctures but easily fixed with there own patches.
    White is not a colour
    gone for a bike ride
    Reputation: culturesponge's Avatar
    Quote Originally Posted by karl711
    thanks for the honest review Karl
    even @ 39.92 euro or $54.00 each - i'm still not sold on the eclipse tubes for anything other than photos on scales
    here's another option: $10 tube purchased at Starbike (SV 14A are $17.45 on schwalbe usa website)
    <a href="https://www.flickr.com/photos/culturesponge/4274681433/" title="Schwalbe SV14A XXlite 26x1.5 innertube + cap + valve collar - 14.01.10 #7530 v2 by culturesponge, on Flickr"><img src="https://farm5.static.flickr.com/4062/4274681433_02bc0cc429.jpg" width="328" height="500" alt="Schwalbe SV14A XXlite 26x1.5 innertube + cap + valve collar - 14.01.10 #7530 v2" /></a>
    Schwalbe SV14A XXlite 26x1.5-2.1 innertube + dust cap + valve collar + talc (scales calibrated with box inplace)
    ...with $2 LBS patch kit
    <a href="https://www.flickr.com/photos/culturesponge/5407611563/" title="5.9g 6 patches + glue + sandapaper - 01.02.11 #7445 v2 by culturesponge, on Flickr"><img src="https://farm6.static.flickr.com/5133/5407611563_78a028fd89.jpg" width="500" height="275" alt="5.9g 6 patches + glue + sandapaper - 01.02.11 #7445 v2" /></a>
    6 patches + glue + sandpaper
    best
    Sorry for the off topic but does anyone know of a lightweight tube for a 2.4 tire?
    Jun 2010
    Quote Originally Posted by XgreygOOse
    have used those Schwalbe 14A's to prep 4x X-King 26x2.4's for tubeless & they worked fine - but not all of the tubes have been 95g - 6 have averaged approx 102g
    ...edit...
    also used the same 95g(ish) Schwalbe 14A XX 26x1.5-2.1 tubes on a ZTR Race 29er wheelset + FF 29x2.0 - t'was abit of a stretch & probably highly not reccomended to do again! - but the tubes stretched & fitted alright
    best
    ups and downs
    1.5"-1.9" is why the Performance tubes are so light
    Don't be a sheep
    Sep 2004
    What the hell are tubes? There is no legitimate reason not to go tubeless.
    "Do not touch the trim"
    Quote Originally Posted by culturesponge
    best
    Cheers culturesponge
    Sorry I'm abit lost, those tubes are for 2.1 tires but you managed to put them on 2.4 tire. Also when you say prep for tubeless, do you mean that you put something like No stans inside the tube
    i inflated the innertube & it expanded from 26x2.1 - 0.3" - to fit the interior dimensions of the 26x2.4 tire
    ...exact same tube also expanded from 26x2.1 to fit a 29x2.0 tire - just add air & hope for the best
    hope that's of help?
