Carbon Handlebar- 620mm+
Printable View
  • 08-26-2009
    DavidR1
    I'm looking for a carbon bar that is over 620mm. I have found that I prefer this size with around 11* of sweep.
    Other then Salsa, does anybody make these? Seems like most carbon bars come in the 520-560mm range. I have tried one of the Easton bars in this lenght, but it is just to short on the front of my rigid bike.
  • 08-26-2009
    bad mechanic
    The Easton MonkeyLite DH at 710mm:
    http://www.eastonbike.com/PRODUCTS/B..._dh_%2709.html
  • 08-26-2009
    rockyuphill
    Are you after a flat bar, a low rise or a riser bar?
  • 08-26-2009
    DavidR1
    Sorry, flat bar in 25.4 would be optimal. No bar ends will be used.
    I was hoping for something lighter then the DH Monkeylite bar.
  • 08-26-2009
    Tiffster
    As far as i know (cause i looked) there are no flat bars over 600mm in 25.4mm
    The best i found was the Easton EC70 riser - 25.4x660mm with "lo - rise" or 1" rise - fits me perfectly. Wouldn't mind a flat bar in 660mm though....
  • 08-26-2009
    DavidR1
    [QUOTE=Tiffster]As far as i know (cause i looked) there are no flat bars over 600mm in 25.4mm
    [QUOTE]
    Salsa makes a flat carbon bar at 660mm and Edge Composites makes one at 610mm. Both of these are available in 25.4mm clamp size.
    I was just searching for lighter alternatives. I have heard that the Salsa bar is pretty stout and I was hoping to find something a bit more forgiving. Plus I wanted to loose a bit more weight over my current Salsa (non-carbon) bar.
  • 08-26-2009
    snowdrifter
    Syntace makes their 31.8 carbon flat bar in 630mm 9* sweep, mine came in under weight at 134 grams.
    Sounds like the Salsa is your bar, you can trim the ends to your desired length.
  • 08-26-2009
    LCW
    easton monkey lite xc - there's a low rise version... 660mm wide... mine are the high rise, 685mm wide and 31.8... but there is a 25.4 version...
    http://www.jensonusa.com/store/produ...eylite+Xc.aspx
  • 08-26-2009
    s4gobabygo
    i'm using an old (CT2) monkeylite low rise at 660mm, 25.4 clamp, weighing in at 142g. i don't know if you'd be able to find one though. the jenson link above is the newer version that seems a tad heavier, but is probably stronger (CNT)
  • 08-26-2009
    BruceBrown
    Outside of the Salsa ProMoto carbon flat bar....
    If you'd be willing to get a new stem (31.8mm), Syntace has a nice flat carbon bar that comes in 2 lengths 600mm and 630mm found here.
  • 08-26-2009
    Ninko
    the best bar ever, Salsa ProMoto carbon flat bar. 11 degrees and 660mm! You can cut them down if you want. I ride them 630 now, but hate it for racing. Go back to 660 soon. Like Kabush:P, what's he riding, 720mm orso? :P
  • 08-30-2009
    le dino
    My Salsa Pro Moto Carbon weighs about 135 grams (uncut) in 25.4 and is much more forgiving than an Easton Monkey Lite XC.
    I m selling it but i'm french, sorry...
