Results 1 to 29 of 29
    Reputation: DaleinTexas's Avatar
    Mar 2016
    Cane Creek EE Wings Ti Crankset
    WOW, I had a chance to put my hands on a set of these a few days ago, I WANT!! Look more like Art Work than a crankset, and LIGHT! The box they were in was heavier than the crankset, but damn that price!
    Nuun Ambassador 2017/2018
    Honey Stinger Ambassador 2018
    Facebook Blog "Run with me"
    Instagram @Run_withme1972
    Ti isn't very stiff. Seems like a strange material to make cranks out of. But they are sexy.
    Small ring in front makes it easier. Small ring in back makes it harder. That blows my mind.
    Ole
    Ole is online now
    Quote Originally Posted by Lenny7 View Post
    Twice as stiff as Race Face Next R, and lighter too. Not too shabby. Check out this video: https://www.youtube.com/watch?v=yU0LNcYF734
    eri
    eri is offline
    Reputation: eri's Avatar
    Sep 2012
    Aluminum is about half as stiff as titanium but has seemed to work ok for cranks.... Stiffness usually dominated by an items shape (size/diameter etc.)
    These are so impractically expensive but I still want. Maybe if my current carbon cranks break? Something tells me these will be hard to find on the uaed market...
    I understood that ti had more give and flex in than aluminum. I stand corrected.
    Reputation: Zerort's Avatar
    Jan 2013
    Here is some fun for you. Both pictures are of 170mm crank lengths so apples to apples.
    Race Face Next SL G4 in comparison.
    BTW, I sold the Race Face and they were new.
    by Silentfoe
    I'm satisfied knowing that what I wear during my "day" job makes me more of a man than you'll ever be.
    Ole
    Ole is online now
    You forgot the mounting screws for the Sram chainring. :-)
    Jan 2013
    Quote Originally Posted by Ole View Post
    Ha, true. Add a few grams.
    by Silentfoe
    Reputation: RSAmerica's Avatar
    I like the vibration dampening of my RF cranks vs XTR Aluminium they replaced. I would think the carbon would have better dampening than the Ti cranks.
    Jan 2013
    I notice no vibration.
    Just like a titanium hardtail rides better than an aluminum hardtail.
    by Silentfoe
    I think I would wet my chamois with every pedal strike.
    eri
    eri is offline
    Sep 2012
    Man I like the product. That video though...
    Clearly engineers or physicists were not involved in the script. A flexible crank doesn't lose energy, it might suck to ride a really flexy crank but since a flexible crank is a spring the energy that goes into flex comes back out. The only loss would be energy lost as heat.
    They should sell the thing on its (many) merits, not confused blather about the performance benefits of extreme stiffness.
    the truth is always a gift because it offers the recipient of that information the chance to change the outcome - Grace Choi
    Ole
    Ole is online now
    Quote Originally Posted by eri View Post
    Except for in a carbon fiber crank, where flex indeed means lost energy. Buy mainly for higher frequencies than pedal frequency.
    When it comes to axle flex, less is better, as it allows the bearings to be loaded correctly. I think this is where most of the stiffness of the EE Wings come from, a Ti axle will be twice as stiff as an alu axle of the same weight and diameter.
    eri
    eri is offline
    Sep 2012
    You're technically right that there is some energy lost as heat, and an aluminum 30mm spindle is more flexible aluminum 30mm spindle, but those effects are way outside of any practical difference. Would you like to estimate the 'crank heating' that's reduced by using these cranks?
    As for bearings... Would you compare stiffness of a flexy 30mm aluminum spindle against a classic steel square taper bb spindle? Again the flex damage delta is out at the lunatic fringe.
    These cranks are light and tough and awesome - no need to sell with snake oil.
    You guys are killing the awesomeness of these cranks with your science!! lol. They're straight up sexy! I got an incredible bro deal from my lbs and bought some (had to - going on a ti frame). But I'll admit my first reaction on getting them out of the box was how light they are.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    That's not possible, the material would have to return 100% of the energy given to it, which doesn't happen. Crank flex is probably a minute player in a complex system of the spindle, bottom bracket, chain and seat stays, etc. If all of these and the crank arm are flexing significantly, you probably are losing out on some significant watts that could be propelling you forward.
    Once we moved to large i-beam, C-section and hollow-forged cranks, I think most of the flexiness issues went away. The old sugino, way-old shimano and cook-bros type stuff was where you got a lot of flex in the cranks. Once we went to octalink 1 we boosted the spindle strength and stiffness significantly. It's only gotten better from there, but those were the biggest improvements IME stiffness-wise.
    ..snip..
    ..snip..
    Here are my old Cook Brothers RSR cranks on my 1990 Fat Chance Yo Eddy with a Ti spindle. Flexy as a wet noodle but Super Cool!
    Quote Originally Posted by RSAmerica View Post
    Badass, I used to want a Yo Eddy so bad.
    eri
    eri is offline
    Sep 2012
    So yeah, I agree it isn't 100%. Even a steel leaf spring doesn't return 100%. But in both cases it is really darn close. Are you disagreeing about the magnitude of the heat loss? Or some biomechanical disadvantage of flex?
    On all bikes with each pedal stroke you're loading a big spring - what doesn't go into forward goes into heat (very small number unless the metal starts to yield), and the rest comes back out as 'up' to the rider.
    Long ago I did a long climb on a super noodly vitus road bike, the original bonded one from the 80s with the steel-sized tubes? Its flex was a problem because it was hard to keep going straight, silly flexy, but it was still fast up hill. The energy that went into flex wasn't being sucked away and wasted but you had to get your timing right, was easy to get discombobulated. Is not at all like a full suspension mtb where excess bobbing is damped by a shock, in that case the shock really is stealing energy by converting it to heat.
    Ya I agree the old square taper spindles were the source of so much flex. I brought them up because in so many cases the bb bearings lasted a really long time even with all that flex. I love the new stiffness but it is a lie to claim huge significant efficiency gains.
    eri
    eri is offline
    Sep 2012
    I had those cranks on a klein I bought used. They were so sweet. I didn't mind the flex at all. Just looking down at them gave me power.
    And the Yo Eddy. Ya. I used to go on short demo rides at the local shop whenever I could - they were sick of me. That bike felt so sweet but I just couldn't admit to myself that a heavy steel bike was worth all the money. They were so beautiful but so so expensive. Absolutely not affordable.
    The Yo Eddy wasn’t a bike it was an attitude!..
    It's the axle
    Reputation: Gregg K's Avatar
    Yikes, thanks for posting this. I have been aiming at getting these cranks, and trying to find actual weights of competing cranks. Now I'm convinced the carbon is lighter. Sorry Eewings. As cool as they are I guess it's carbon fiber for my new build.
    Note to self: 85% of FTP for 20 min.
    Jan 2013
    Quote Originally Posted by Gregg K View Post
    By 7-10 grams? Yeah huge savings.
    by Silentfoe
    I had Kooka cranks...and I think they were the forged ones, because they didn't break doing freeride.
    The Next cranks are even lighter after they've failed. This set in particular was used on a fat-bike and never saw any impacts.
    Jan 2013
Name:	IMG_4453 (Edited).jpg
    Lot of failed RF cranks. I'll take the extra 7 grams
    by Silentfoe
    If the these came in 165mm I would have treated myself during the CC Black Friday sale- 20% off
    OG Ripley v2
    And the 176 q factor is a little annoying as well.
    It's the axle
    Wow. I'm reconsidering Eewings, but damn, this bike I'm building is going to be over ten grand. It'll be nice though.
  1. Looking for Plastic "Wings" for Toupe.
    By Thatshowiroll in forum Weight Weenies
    Last Post: 08-04-2014, 03:53 PM
  2. Crank Brothers mallet pedals, spring is jamming wings open
    By SlowJoeCrow in forum General Discussion
    Last Post: 04-07-2014, 06:17 AM
  3. Need your opinions: Wings springs vs Elastomers
    By boroef in forum Vintage, Retro, Classic
    Last Post: 05-17-2012, 12:40 PM
  4. Wings Springs
    By biss-ness in forum Shocks and Suspension
    Last Post: 05-16-2012, 08:05 AM
  5. Wings suspension
    By Sjb93 in forum Shocks and Suspension
    Last Post: 01-29-2011, 03:05 AM
Members who have read this thread: 155
© Copyright 2018 VerticalScope Inc. All rights reserved.
