Can You Make A Chris King Headset Lighter- Mtbr.com
Results 1 to 9 of 9
    Does anyone know if you can make a Chris King headseat lighter. I know you can get a Ti lower ring but can you get a Ti nut and if so where. I do not know the size so if you know please let me know.
    used to be uno-speedo....
    Reputation: dirtdrop's Avatar
    You could machine the top race!
    PurpleIsFasterThanRed!
    Reputation: vi3dr0's Avatar
    Adamello from www.light-bike.com lighten it up almost 20g! Mind there's integrated carbon spacer, which adds another 2-4g.
    http://www.light-bike.com/forum/viewtopic.php?t=1127
    I could translate anything if photos are not enough for you.
    Greetz
    vi3dr0
    Aluminium Carbon / Damping Composite
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by 1coolfish
    Lower ring? Do you mean crown race? Yes, the standard crown race is steel and ti would be lighter.
    The easiest way to cut weight is to not use the star nut and top cap. Use a long bolt to go all the way through the steerer or an expander top cap to adjust the headset then remove it after you tighten the stem bolts. You can do this with any threadless headset. The only down side is you will not be able to adjust the HS on the trail, if needed.
    mtbtires.com
    Reputation: Tiffster's Avatar
    Im using a carbon top cap, alloy bolt and Ti crown race to lighten mine up.
    Quote Originally Posted by shiggy
    i have done this on many of my bikes no prob, have over 3000 miles doin this and never had one come lose all on cane creek cheapys, i bought a new king headset the other day i have rode it 3 times and all 3 times it has came lose on me, i dont know if the bearings are loaded diff or what but i put the star nut back in on my king headset!!
    Where can I get a lighter star nut from?
    STS
    STS is offline
    Reputation: STS's Avatar
    and ceramic bearings?
    a lighter star nut? this is getting out of hand...
