Best lightweight gearing combination- Mtbr.com
Results 1 to 20 of 20
    Hey WW's,
    I recently acquired an S-Works road crankset that has 172.5 mm crankarms. A customer at the LBS purchased a Carbon S-works 29'er and swapped cranksets (175mm). I plan on swapping spiders+chainrings and using a Zipp Vuma Quad adapter to make it fit on my aluminum Specialized Hardtail frame.
    My question is, what would be the lightest, best XC racing gearing+shifter combination with the stock 24/38 chainrings? I was thinking Dura Ace 7800 12-25 cassette with my current XTR rear derailleur and xtr shifter, but worry that the 38/12 will be too short of gearing. I never use the small chainring in the local trails/racing, so I am not as worried about the 24/25, which would still be less than a 1:1 ratio.
    Any input/other recommendations appreciated! Worst case scenario I can get 42/28 chainrings and use an xtr 11-32 cassette.
    "They Call Me Bone'z"
    Reputation: facelessfools's Avatar
    i did a coupple races at the end of this season on a 34t rotor ring and a 11-34t ti cassette. 34 11 was high enough for the roads and 1 to 1 was low enough for me.
    ill be going 35t ring and 11-36t xx cassette for 2012. if i dont like it i may go with a road cassette like 27-11 and 25/36 chainrings.
    RAH!
    The only road cassettes that are wide ratio 9 speed road cassettes that I know of are 12-27, unless anybody can correct me on that. In all honesty, with my current triple I have never found myself in the big ring and the 11t cog, so I think I should be able to get away with running a 38/24 crankset and an 11-25 D/A cassette.
    On a side note, is the 7800 D/A rear derailleur compatible with an XTR shifter? or should I stick with my current XTR?
    You could use 11-28 slx 9 speed cassette (230 gram) light and cheap
    i had 38/27t rings previously and raced that for a majority of the season too. 38 11 is plenty tall for the west coast cup.
    RAH!
    Reputation: bikerboyj17's Avatar
    OP: Wait, an S-works road crankset will work on a mountain bike? I thought the spindle was too short.
    Can you please share how you set up this crankset? I have a specialized aluminum hardtail too. What model do you have?
    What category do you race and what kind of terrain?
    Quote Originally Posted by Kwik View Post
    Thats about 80 grams heavier than a D/A...
    Quote Originally Posted by facelessfools View Post
    Thanks for the input!
    Quote Originally Posted by bikerboyj17 View Post
    I got my frame special, its a 2011 Aluminum M5 Hardtail. We plan on swapping spiders, it should work with the Vuma Quad BB.
    Quote Originally Posted by jthurd View Post
    Juniors/Cat 2, varying terrain each race.
    Update, checked the spindle length, the road crankset spindle is too short :[
    Anybody know of a lightweight, 172.5mm mountain crankset besides XTR?
    Lightning Cranks, although IMO XTR would be your best option.
    Rotor make their Agilis and 3D crankset in 172.5 as well.
    Extralite!!
    RAH!
    Profile elite pro. light, stiff, and 172.5
    Add 175g for octalink DA (68mm) BB.
    I have 2 pair, best budget WW crankset... if you can find them.
    Arms are carbon wrapped Al... ie you wont break them.
    Spiders are replaceable. Uses the same spider as the MTB specific Profile alpine pro (heavy) and old school XTR cranksets.
    Shown with w/ TA 30/42 rings.
    Currently putting together a 172.5 SiSL/Zipp Vuma 25/38t setup on a 29er Lenz. Doing a little Jerry-rigging to get it to work on non BB30. This would be a uber light option if your Spec is BB30, albeit expensive.
    Attached Thumbnails Attached Thumbnails Best lightweight gearing combination-profileelite.jpg
    jthurd- Is this the same crankset?
    http://www.trivillage.com/procra0700...ode=PROCRA0702
    it uses an octalink BB.... id say make sure you go with an external bearing system. better stiffness lighter and maintenance.
    RAH!
    yup, thats them.
    with the 94bcd spider/rings and octalink BB your good to go.
    If you have a 68mm shell BB you can use a 108mm DA 7700 needle bearing BB which are pretty light. If your frame is 73mm then you have to get creative with the DA BB because the drive side sleeve will screw too far into the BB to attach the lockring. I used some blue locktight to hold it in place without the lockring- worked fine. If you not into every gram just buy an XTR 113mm or 117mm octalink BB for a 73mm shell. I think they are around 200 grams? Its sealed better also, but not rebuildable like the DA.
    If D/A octalink was stiff enough for Lance in his first couple tours I think its good enough for us.
    Other than lightning, extralite, or SiSL show me a lighter 172.5 MTB crankset. You can by those for $5-600, or get this for cheap. Octalink BB's can be had all over the bay for less than 35 bucks, octalink XTR will last just as long as some outboard BBs. standard splined BB tool + crank puller- pretty easy to work with. Sure there are better, lighter cranksets. Depends on what you want to spend.
    Yhu all mad. I work for a bike shop so I can get Specialized stuff at attractive employee deals, but unfortunately they do not have a 172.5mm MTB crank option. Perhaps I'll just use the 175's and learn to live with them?
    Get the 175's at a cheap price and be done with it. Post the results of your installation. I'm curious as I have a similar frame.
    [QUOTE=fryer;8276565]Thats about 80 grams heavier than a D/A...
    My dura ace 12- 27 weighed 180 grams, thats just 50 grams lighter. With the slx 11-28 you also have good gear spread at the rear.
    The money you save on the slx cassette, you could spend on lighter not wearing parts, My advice, but I'm not a real weightweeny any more.
  1. Best Combination?
    By GBR1 in forum Wheels and Tires
    Last Post: 10-17-2008, 06:40 PM
  2. A bad combination...
    By Walt Dizzy in forum Wheels and Tires
    Last Post: 02-29-2008, 09:37 PM
  3. Is this a right combination?
    By znarf420 in forum Turner
    Last Post: 12-19-2006, 09:07 AM
  4. Lightweight rider... lightweight wheels?
    By hiccup in forum Wheels and Tires
    Last Post: 05-06-2006, 09:23 PM
  5. Replies: 1
    Last Post: 01-15-2006, 10:52 AM
