bcd on Middleburn duo chainrings- Mtbr.com
Results 1 to 8 of 8
    Rock and/or Roll
    Reputation: turbogrover's Avatar
    Dec 2005
    I am asking this question here since it pertains to my weightweenie-ness, lol.
    I would like to know the bolt circle diameter of the outer ring on the Middleburn duo chainrings. I didn't see it listed on their website. I want to know if I could use the outer ring on a FSA K-Force light 386 carbon crankset. The 386 crankset uses an 86mm bcd. Thanks!
    Hack Racer
    Reputation: Cheers!'s Avatar
    If you have a DUO setup, you can only run the DUO rings. Because the spider is integrated into the small ring, and there is a step on the small ring that matches up with the big ring.
    Rock and/or Roll
    Dec 2005
    Quote Originally Posted by Cheers! View Post
    You have completely missed the point of my question entirely.
    I must've not explained well enough.
    Let me simplify:
    The outer ring on a Middleburn duo.
    What is the bolt pattern?
    Hack Racer
    why don't you contact middleburn and find out?
    contact
    all enquiries
    matthew@middleburn.co.uk
    Phone: 01420 520223
    Fax: 01420 521142
    address
    Middleburn Components
    Unit 5 Bentley Park
    Blacknest Industrial Estate
    Blacknest
    Alton
    Hampshire
    GU34 4PX
    Take a look at the duo chainring page:
    Middleburn bicycle components, cranks, chainrings, hubs and accessories
    The large chainring attaches directly to the crank via a splined interface, and not by chainring bolts. The small chainring then attaches to the large chainring.
    So even if the bolt pattern was the same on the middleburn and the FSA, you'd have to cut out the center spline section on the middleburn chainring in order to use it. That would probably leave it not as strong as it should be.
    That is actually backwards. On the Duo crankset it is the small inner ring that attaches to the crank arms with a center lockring and the larger outer ring is then bolted to the inner ring using 3 standard double chainring bolts.
    My Duo crankset BCD measured 82mm by way of both regular diameter and C-C*1.155.
    I stand corrected! Well too bad the BCD doesn't match.
    Rock and/or Roll
    Dec 2005
    Oh well, they don't match. Thanks for measuring them! It was a good idea at least.
  1. Middleburn duo chainrings
    By turbogrover in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-15-2011, 11:01 PM
  2. M960 XTR chainrings - Middleburn Vs. Blackspire
    By KrisRayner in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-22-2009, 10:34 PM
  3. middleburn chainrings, hope BB v Shimano XT
    By scrubs in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-17-2008, 02:55 PM
  4. Where Can I Buy Middleburn chainrings?
    By wyatt in forum 29er Bikes
    Last Post: 04-27-2007, 07:16 AM
  5. Chainrings: Middleburn Hardcoat/Slickshift vs Blackspire Super Pro vs Raceface Race
    By lalittle in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-22-2006, 02:43 PM
