4.5 mm Pnuematic tubing as housing- Mtbr.com
Results 1 to 6 of 6
    No longer 26
    Reputation: G-Live's Avatar
    See http://beta.velonews.com/article/730...und-road-bike-
    Anyone else ever try this or is it light just because of short runs of housing needed on a roadie?
    G
    You can't depend on honest answers from dependant hands...
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    Sounds like its microline housing, I don't have any to check though as none of my paintball guns use the stuff (its only rated to about 200psi working pressure and none of my guns run that low) but its certainly stiff enough to use as shifter casing. Not sure about for brake cables if the working pressure rating is high enough to resist cracking. Probably would be sufficient given the short sections of housing involved.
    I don't post to generate business for myself or make like I'm better than sliced bread
    Reputation: nino's Avatar
    Tune Plastic or Magura line
    Quote Originally Posted by G-Live
    G
    Tune Plastic housig works great on shifters AND brakes and at just 18g/m is extremely light. i still use it on my Scott Scale. hard to get as Tune doesn't offer it anymore. i have bought a bunch back then which should do fine for the next couple of bikes... they came in 50cm long pieces so on bikes with shorter lenghts these worked great.the longer the housing the softer the feel on the brakes becomes. they had an inner teflon liner as well so well suited to be used with wire inside. other plastic tubes don't have such a "cover" so over time wires will eat through.
    then there is guys using Magura hydraulic line but this is pretty soft. however they say it works...
    STS
    STS is offline
    Reputation: STS's Avatar
    I tried magura tubes for shifting, and they were terrible soft
    tune are the only plastic ones that work, at least for shifting
    Reputation: Tiffster's Avatar
    Why did Tune stop making the cables?
    Liability?
