Why is my headset not staying tight?- Mtbr.com
Results 1 to 10 of 10
    Mar 2018
    So I recently finished turning a 91 Schwinn High Plain into a "gravel" bike. I have taken it on two rides so far and on both rides my headset has ended up being a little lose after a knock. I went to bunny hop a log mistimed it badly and it brought the front wheel down hard and after that the headset was lose (applying the front brake the fork moved). Then on the second ride I went OTB in a flooded part of a gravel road which turned out to have a hole in it and the headset was lose again after that. Is this normal with threaded headsets? If I tighten it down anymore it seemed like it was adding resistance to turning the bars, which seems like it would be too tight. The headset is Tange headset. I have never had a bike with anything other then a 1 1/8" threadless.
    Ragley Big Wig, Sunday Soundwave (BMX), 91 Schwinn High Plain (single speed "gravel" bike), Nashbar CXSS (workout)
    Reputation: J.B. Weld's Avatar
    Do you have a thin wrench to hold the top bearing race while you tighten the locknut against it? If they're not locked together it will never stay tight. Otherwise you may need to overhaul it and inspect the races & bearings to see what's wrong.
    I brake for stinkbugs
    Out spokin'
    Dec 1999
    Crown race fully seated on the fork?
    =sParty
    disciplesofdirt.org
    Mar 2018
    Quote Originally Posted by J.B. Weld View Post
    Yeah I did. It is a brand new headset with now about 35 miles on it.
    Mar 2018
    Quote Originally Posted by Sparticus View Post
    =sParty
    I will double check that.
    taste death, live life.
    Reputation: super_stein's Avatar
    I had a Ritchey headset that would not behave. I ultimately installed a Gorilla Headlock...problem solved.
    Mountain Tamer Chainring Adapters, Gorilla Brake Beefers, Gorilla Headlocks and more
    be1
    be1 is offline
    Reputation: be1's Avatar
    Sep 2013
    you can also get a threadless headset, threadless fork, and new stem. i've done that before. works every time. threaded headsets aren't the easiest to use.
    wink, wink. nudge, nudge. say no more...
    Quote Originally Posted by 93EXCivic View Post
    If you're getting the adjustment right and locking the race and locknut tightly together and it still comes loose right away then something's not right, sometimes it can be as simple as a dust seal on upside-down.
    Adjusting a threaded headset can be trickier than threadless but principals are the same. The best test I know of to make sure a headset isn't loose after adjustment is to give the front wheel a knock with your fist (on stand) or let the front wheel bounce on the ground, if it's even slightly loose it will make a distinctive noise from the vibration. Conversely it's too tight if the wheel won't return to center when released from ~45% (again, on a stand.)
    Also the adjustment should be a smooth progression from smooth to tight, if it goes from too loose to too tight with just a small turn of the top bearing race it's almost always an indication that something is wrong inside, as mentioned it could be a crown race that isn't seated or several other things.
    Sorry if that's too much info, good luck!
    Mar 2018
    Thanks. I will give everything a once over again. If that doesn't work, I'll go to the LBS and see what they say.
    Jun 2012
    Check the stack height. Maybe the lock nut is bottoming out on the steerer tube before properly tightening. If that's the case, you can often get away with adding a second keyed washer between the upper race and lock nut.
  1. Spokes not staying tight?
    By cramey in forum Wheels and Tires
    Last Post: 03-31-2016, 07:38 AM
  2. Bolt on skewers. How tight is to tight??
    By vizsladog in forum 29er Bikes
    Last Post: 03-05-2011, 10:25 PM
  3. Tire clearance..how tight is too tight?
    By morandi in forum 29er Bikes
    Last Post: 01-14-2011, 10:28 AM
  4. Pike Maxle not staying tight
    By Flyer in forum Shocks and Suspension
    Last Post: 04-28-2008, 08:45 AM
  5. chain tensioner not staying tight
    By mrbray101 in forum Singlespeed
    Last Post: 09-21-2006, 05:42 PM
Members who have read this thread: 40
