Vintage Stumpjumper Sizing- Mtbr.com
Results 1 to 10 of 10
    Mar 2011
    Hi all,
    I am interested in a 1994 Rockhopper Comp that is available locally. It is a 20 frame. I am 6 foot 1 and generally ride a large in modern mountain bikes. It looks like the biggest they made that year was a 21.5. Should I hold out for that or would the 20 probably be a good fit? I know for is very much preference based, but I would appreciate some advice.
    Hybrid Leftys aren't real Moderator
    Feb 2005
    20 won't be bad, but at over 6 feet, were you buying one off the showroom floor and had the option? A 21.5 would likely feel better, just a bit longer in the top tube....
    Now an 18? Yeah, no.
    Cannondale Lefty and HeadShock servicing, wheel building, etc...
    www.mendoncyclesmith.com
    Ride what you like!
    Reputation: MattiThundrrr's Avatar
    Jul 2019
    I'm on a 94 Hardrock, it's 18 or 18.5, definitely medium. I'm 5'10, and it's a skootch too small, I'd be more comfortable on a size bigger. If that helps you at all.
    Post picks of the 'hopper if you pull the trigger!
    The revolution starts now
    When you rise above your fear
    And tear the walls around you down
    The revolution starts here
    Reputation: AlmostGreenGuy's Avatar
    Feb 2012
    Im 510, with a 33 cycling inseam. I ride what I believe is a 20 1993 Rockhopper. It fits okay, other than needing an extra long seat post and a taller than normal stem. Id actually do better with size up if I could find one.
    Rockin' an 18" 93 stumpy at just under 5'10" 31" inseam. Wouldn't want it any larger. at 6'1" 20" should be doable.
    Depends if you're going to run it stock or if you're going to run a tall stem & risers which bring the bars back closer. Lower stem & higher rise bars will help to keep that length & comfort you'll most likely want.
    Attached Thumbnails Attached Thumbnails Vintage Stumpjumper Sizing-new-green-bits1.jpg
    83 Ritchey Everest
    95 Bianchi Mega Tube ti
    2015 Kona Operator Supreme
    2019 Kona Process 153 CR 29
    Feb 2005
    ^Sweet color "vision" sir...^
    Ride what you like!
    Jul 2019
    Both the 2 tone Rocky and green Stumpy are gorgeous, I love the logos n labels from that gen! Here's the dumb guy question: I've seen several places listing different measurements for the same size bike, ie medium is 17.5 on one site, 18 on another. So what's supposed to be measured, from center of bottom bracket to top tube, or to the top of the seatpost, including the extension above the top tube?
    Yeah, when I saw the green one in almost unused condition I had to own it. Wife & daughter just bought me the child seat & I couldn't bring myself it install it on my Ti bike. N+1 for any reason. Had to get the colorful bits for my daughter, she's got to ride in style, and the stock saddle was killing my arse.
    Sizing measurements on mine, 18" Center of BB to about 2mm short of top of the seat collar.
    83 Ritchey Everest
    Reputation: dbhammercycle's Avatar
    eshew: A while back, I saw a stumpy of that model on the back of pickup at the local gas station with a bunch of crap that looked to be heading for the steel bin. I wanted to wait to make an offer but it was date night and we were dressed oh so nice. Ok, I didn't care that I was wearing a suit to go to the symphony but the wife gave me a murderous look so I had to let it go... I'm basically the same weight and inseam and the frame was also an 18"... I'm ok though, I mean the wife let me live so...
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    Feb 2012
    My measurements on the inside triangle, measured from the center of the tubes, is 23"x19"x25".
  1. Vintage rider on vintage bike
    By Hunterliney in forum Vintage, Retro, Classic
    Last Post: 10-03-2013, 01:13 AM
  2. Vintage vintage bike hauler
    By Bigwheel in forum Vintage, Retro, Classic
    Last Post: 09-14-2013, 10:31 PM
  3. Vintage Bikes in a Vintage DH race
    By AmbientLight in forum Vintage, Retro, Classic
    Last Post: 04-30-2013, 04:08 AM
  4. Stumpjumper FSR vs. Stumpjumper Comp vs. Stumpjumper Expert
    By colorado_mark in forum All Mountain
    Last Post: 07-29-2006, 04:12 PM
  5. Some vintage (and not so vintage) Mammoth shots
    By Fillet-brazed in forum Vintage, Retro, Classic
    Last Post: 09-24-2004, 09:18 PM
