Vintage belt drive Circa 1995, who made it- Mtbr.com
Results 1 to 24 of 24
    mountaingoatcycles.com
    Reputation: First Flight's Avatar
    Just picked up 2 of these bikes (serial # 10 and #14). Figured I would see if anyone recognized them before revealing the entire bike. These were made circa 1995 and there is a web page on the MOMBAT.org web site with copies of some ads. 7 speed Sachs internal hub with a toothed Gates drive belt, pretty cool for almost 20 years ago.
    Attached Thumbnails Attached Thumbnails Vintage belt drive Circa 1995, who made it-dscn3206.jpg
    Reputation: DoubleCentury's Avatar
    Dan/Ed, based on the goofy crank.
    Figured the crank was the giveaway, but couldn't get a shot of the belt without the sprocket! Guess this would have made it even more obvious.
    Attached Thumbnails Attached Thumbnails Vintage belt drive Circa 1995, who made it-danedrpedal.jpg
    Pretty much everything we have on the company is at MOMBATan-Ed History
    Anybody got more??
    Hybrid Leftys aren't real Moderator
    Feb 2005
    I hope it skips less than mine did...
    Not impressed.
    Belt drive that is, looking forward to full pics of this.
    Cannondale Lefty and HeadShock servicing, wheel building, etc...
    www.mendoncyclesmith.com
    We need to have a contest to name all the things wrong with this bike!
    Attached Thumbnails Attached Thumbnails Vintage belt drive Circa 1995, who made it-danedrside.jpg
    Feb 2005
    That thing is way cool!
    Does it ride as weird as I think it will?
    I'm imagining something akin to a SoftRide beam, boingyboingyboingy.....
    As to what's wrong? I'll start, it's missing seat stays (I know, the easy one to guess)!
    The rear shock alone is horrible in a number of ways- too short to provide either travel or damping.
    _
    That thing is awesome!!!
    Giant Trance X4
    Giant Talon 29er
    Specialized Hardrock
    [FONT="Comic Sans MS"][/FONT]
    Reputation: laffeaux's Avatar
    Quote Originally Posted by First Flight View Post
    I assume that "lots" of rear travel combined with no front travel (unless you count the stem) would be the biggest issue. Also I'd assume that the rear end would be all over the place given that there is little to prevent it from flexing.
    But a neat bike none the less.
    Each bicycle owned exponentially increases the probability that none is working correctly.
    Dan of Dan/Ed called the shop today so hopefully we will have more info coming soon!
    How about all of the stress from the suspension being put into the bolt that pierces the elastomer in exactly the place where there isn't much meat? Seems like there should have been some type of "pocket" on the bike, like the front, to distribute the load?
    In this picture, you can see a groove on the back of the swing arm where the bolt goes to hold the brake mount on. There isn't a lot of excessive thickness on the swing arm and they machine a stress riser right down the middle of it
    Attached Thumbnails Attached Thumbnails Vintage belt drive Circa 1995, who made it-danedrmount.jpg
    more beers, less gears
    and i don't see anything to hold the belt on the front cog.
    can't imagine that this should work.
    Static display.
    _
    Quote Originally Posted by rigidftw View Post
    Just cleaning it up on the stand and riding around for pictures, the belt seemed to track true and had no problem staying on. The bike uses vertical dropouts so there isn't any way to account for belt stretch or different sized cogs.
    Full set of pictures are now up @ MOMBAT: 1995 Dan/Ed (red)
    Certified Bike Junkie
    Reputation: muddybuddy's Avatar
    Is the little tensioner pully the only thing with guides to keep the belt in place?
    Need: McMahon brake for roller cam mounts, Mountain Goat fork.
    is it rideable, or does the belt just fall off the front? is this how it was designed, or is there something to guide the belt up front that's missing? very intriguing.
    Quote Originally Posted by s4gobabygo View Post
    Just riding it around casually, the belt stayed on and didn't wander.
    cool! so it's not missing any kind of guide in the front that you're aware of? it certainly looks like it would fall right off haha!
    Reputation: Mr Cabletwitch's Avatar
    I found another.
    Quote Originally Posted by Malibu412
    Cableb!tch: living, breathing proof you can be right and.still be a dick.
    Any full bike shots? Serial number? (stamped on the swing arm)
    No thats the only decent pic I have. Its hanging in a bike shop along with a couple other cool and interesting bikes.
