Results 1 to 5 of 5
    Dec 2018
    V-brakes for ST M739 Shifters?
    Trying to upgrade my older bike from a cantilever to vbrakes. Bought a set of Shimano ST M739 3x8 XT Deore shift levers and was wondering if they work with Shimano V brakes. I know the pull length is different with vbrakes. Also, are vbrakes all the same? Meaning, should I buy a vintage m739 vbrakes or get something newer??
    Feb 2005
    All V's are more or less the same, leverage wise.
    Using canti levers with them will *work*?
    But it feels really crummy, and your set up window for remotely functional is super narrow.
    Problem Solvers used to offer the Travel Agent, a pulley that changed the leverage ratio, but they seem to have gone the way of the Dodo. Quick web search didn't turn up a viable alternative, but poking around, you should be able to scare a few up.
    They were a tad fiddly, but once set up, worked like a charm, and felt great.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Reputation: clintj's Avatar
    Nov 2018
    I'm looking at a set on eBay, and the pivot to anchor distance looks like V brake spec to me.
    I'm reaching way back to my bike shop days here, but I believe 8 speed and the V brakes came out around 95 or so in XT and XTR, and were scarce for a little while. My Zaskar LE frameset came from a bike one of our companion stores ordered and stripped to build an XTR bike for a customer, and I remember building bikes for our more hardcore customers with XT Vbrakes around that year.
    Sent from my Pixel 2 using Tapatalk
    XT 739 is V-brake compatible, the previous 737 model was canti brake.
    Just don't buy anything described as a mini v-brake. they are some weird bastard child that is halfway between V and canti leverage, anything else should be fine.
    Although the XT 739 V-brakes are notorious for loose pivots. So maybe avoid those unless they are new, or you can find the shim/rebuild kit for them.
    Dec 2018
    Thank you all for you input! I really appreciate it and am learning quite a lot thru forums like these and other resources.
  1. Shimano Deore XT RD M739 questions
    By gdb2b in forum General Discussion
    Last Post: 07-15-2012, 09:07 AM
  2. Replacing chainring on Shimano FC M739 XT Cranks
    By kendobari in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-08-2012, 03:26 AM
  3. Replacement cable - Shimano SL XT M739
    By javelina1 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-03-2012, 09:36 PM
  4. xt m739 shifter/brake 8 speed
    By WalleyesAndTNT in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-11-2011, 08:02 PM
  5. Shimano Deore XT M739 shifter/brake lever combo
    By K9COP92 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-01-2011, 12:52 PM
Members who have read this thread: 21
