Suspension fork suggestions for '93 Rockhopper- Mtbr.com
Results 1 to 21 of 21
    Can I get some suggestions on what would be the best performing fork for my Rockhopper?
    I'm also looking for the least outlay of cash, so it would have to be a threaded fork.
    I've got a 2012 geared rockhopper, but I want to try more trail singlespeeding also. I tried with the rigid fork, but between that and the 26" wheels, the trails beat me up a bit.
    Suspension fork suggestions for '93 Rockhopper-uploadfromtaptalk1321766324891.jpg
    Sent from my Galaxy Tab using Tapatalk
    Reputation: proto2000's Avatar
    Try some fat 2.3" tires, those skinny ones don't absorb bumps well. Best to leave the rigid fork for resale value too.
    Too many bikes, and just enough time to ride them.
    Quote Originally Posted by proto2000 View Post
    Those are just the 1.5" slicks for around town riding. I've got some 2.2's that I run at 22/26 psi, but I was thinking of putting an older model rock shox or manitou to spare some of the bigger hits on my local trails.
    I'm also not really concerned about resale value since I've had this bike for almost 20 years now and it has alot of sentimental value.
    Ah. So the best bet is any cheap fork you can afford.
    Any suggestions on models to check ebay and craigslist for that have a 1" threaded steerer and is cantilever compatible?
    Reputation: djmuff's Avatar
    Sep 2004
    The best performing fork is the one you have- the original rigid. I'd stick with that and just bend your elbows a little more.
    If you are set on a suspension fork, a Judy is going to be about the best you can do that will work with what you have.
    Reputation: rudymexico's Avatar
    Aug 2010
    I would keep the rigid fork, but if you like a suspension fork, maybe a Mag 20/21, air and oil, Manitou or Manitou 2, but the original elastomers are surely gone...
    defender of bad taste
    Nov 2007
    sigh...
    5 is the old new black; 6 is the new new black...
    Quote Originally Posted by djmuff View Post
    So I should basically just HTFU. Maybe its more trouble than its worth. I keep going back and forth.
    Sent from my EVO 4G using Tapatalk
    Quote Originally Posted by rudymexico View Post
    I would definitely keep the fork still, but just swap depending on my mood and conditions if I found a squish fork.
    Feb 2007
    The only forks that would have short enough travel, and a 1" threaded steerer tube are either going to be extremely cheap and weigh a ton (think dept. store bikes), or be 15 years old and so obsolete that their performance is going to be poor, not to mention the increasing difficulty in finding parts. For me at least, old suspension parts are rarely worth using. Modern suspension is so much better than the stuff from the 90s that I'd rather upgrade to a rigid fork (which is also why so many folks are urging you to stay rigid). And you can't really put a modern fork on that bike because all the steerer tubes are 1 1/8 threadless and at least 80mm travel, which is going to be way too long for that bike.
    Having fun and riding aggressively on a rigid bike is a skill set that has to be developed. Stay loose, bend the elbows alot, etc. Big tires at low air pressure helps alot too, along with some squishy grips.
    Nov 2007
    Quote Originally Posted by vwvapor View Post
    We're all too nice to put it that bluntly, and it's not really about that. Any suspension fork you put on there, be it ancient or modern, will actually degrade the ride you currently enjoy in one way or another.
    Trouble is, you're riding the same trails on your 2012 bike and your 1993 bike, the 1993 bike will superficially seem like a less enjoyable ride. Perhaps save the hydroformed 100mm forked rolling billboard for the trails that seem unenjoyable on the steel 'hopper, and find yourself some nice twisty flowy smooth singletrack to remind you how much fun a rigid bike can be?
    Thanks for all the advice everyone. I think I'll follow the recommendations of those wiser than I am and leave it as it is. Might as well keep the rides as different as possible for the variety. I did think the project might be fun though.
    Quote Originally Posted by mechagouki View Post
    That's pretty funny and so true.
    Oct 2007
    You can try calling B Rose at Shockspital and see if he has anything laying around. He digs the older stuff but I don't know what he has on hand.
    Otherwise, ride the hell out of 'er as she is. Besides, it's always great to ride a rigid steel 26'er and hang on the wheel of some chump riding a modern, high-buck bike.
    Keep the Rubber Side Down!
    Wanted: Judy FSX decals
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    That's a really nice paint job. I didn't realize Specialized did a fade. Nice bike.
    A garage full of steel frames means happiness.
    Quote Originally Posted by Slimpee View Post
    That's a nice resource. Thanks!
    Quote Originally Posted by CS2 View Post
    Thanks! Call me blind though, but I never even noticed that the paint job transitioned/faded from front to rear until the first time I took a photo of the bike. Maybe it's not as noticeable in person.
    I like the oldschool Judy XC fork....inexpensive and durable.
    CS2
    CS2 is offline
    You can see it in the photo. It's really a nice paint job. The build looks like it would be fun the way it is. Nice job.
    I'm just messing with you
    Reputation: wv_bob's Avatar
    Unless you're in the flatlands, I'd say the gearing didn't do you any favors either.
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    Quote Originally Posted by wv_bob View Post
    I run 42x18 with the slicks for casual road riding and swap in a 32t chainring and knobbies for the trails.
  1. Suggestions-suspension fork with mimimal maintenance
    By allroy71 in forum Shocks and Suspension
    Last Post: 05-07-2011, 11:20 AM
  2. Upgrading fork on Rockhopper, any suggestions?
    By aracil2185 in forum Shocks and Suspension
    Last Post: 09-25-2009, 07:40 AM
  3. Suspension fork suggestions for clyde?
    By Rocket Reducer No. 62 in forum Singlespeed
    Last Post: 08-12-2004, 06:16 PM
  4. Suspension fork suggestions?
    By Alan in forum Singlespeed
    Last Post: 05-11-2004, 08:04 AM
