Suntour catalog scans including Roller Cam set up- Mtbr.com
Results 1 to 5 of 5
    mountaingoatcycles.com
    Reputation: First Flight's Avatar
    Just scanned in a bunch of Suntour catalogs @ https://mombat.org/Suntour.htm
    Roller cam set up instructions.
    slow
    Reputation: sgltrak's Avatar
    Feb 2005
    Thanks for those. I had copies of most of those and threw them away several years ago.
    I also enjoyed the write-up on the Coors Classic, having seen various stages numerous times. I understand there is talk of bringing it back in some form or another.
    Ride Everything
    Reputation: GRAVELBIKE's Avatar
    If it's not too much trouble, could you check the capacity of a front X-1 derailleur? I'm building up a touring/commuter bike, and was thinking about using an X-1. It needs to be compatible with 26/36/48t rings.
    Thanks.
    GRAVELBIKE.COM - ride everything
    Thank you soooo much for that Jeff- I've been trying to dink with my Roller Cams for a while and I'm having trouble. The fact that I'm pretty much mechanically incompetent has nothing to do with that... I'm sure...
    *-Recipient of the 2006 Time Magazine "Man Of The Year" Award.-*
    Jun 2012
    In the 1st diagram it shows a male threaded mount for the roller cam arm. I have two different 1987 Cannondale mountain bikes, both with roller cams both the same model ( by frame color match with catalog). The two bikes have different rear mounts on them, one female threaded, one male. The rear roller cam brake mounts I've seen on Cannondales are not brazed on, but instead thread into a coarse female threaded hole in the seat stays. Does anyone know why the two types? Can you get these parts anywhere? Most of the roller cams I've ever seen mount with a male allen screw into a female threaded mount.
