Spindle Size for 1992 Trek 8900- Mtbr.com
Results 1 to 3 of 3
    Jul 2020
    Hi there,
    Does someone have the factory spindle size for a 92 Trek 8900?
    I have a 113mm on it now but the shifting isn't as smooth as I am hoping so want to check if I missed something.
    Thanks.
    Hybrid Leftys aren't real Moderator
    Feb 2005
    It's not really based on the bike, so much as the cranks.
    113 should be in the right range "for the era", but the general rule of thumb (if shooting from the hip) would be having the chainrings as reasonably close as possible to the chain stay without flex causing it to rub the frame.
    I'd use that guideline to help, if you don't truly know the correct spindle length, for the crank used, to get whatever the "proper" chainline is that the crank maker built them for.
    BB spindle length shouldn't terribly impact shifting "smoothness" though, it'll show itself with rings rubbing on frame, or rings too far away that certain combinations don't work well or at all.
    Cannondale Lefty and HeadShock servicing, wheel building, etc...
    www.mendoncyclesmith.com
    Jul 2020
    thanks a lot!
  1. 1999 Trek 8900 frame - Dropout spacing off by too much?
    By SoundMind in forum Bike and Frame discussion
    Last Post: 12-11-2016, 12:45 PM
  2. Show your TREK 8900 pictures!!!!!
    By Zion Rasta in forum Trek
    Last Post: 02-23-2013, 05:09 AM
  3. 1999 Trek 8900 Build
    By jcayce in forum Trek
    Last Post: 08-25-2012, 04:53 PM
  4. 2006 Trek 8900 build-up
    Last Post: 05-20-2007, 03:34 PM
  5. 1999 Trek 8900
    Last Post: 01-04-2006, 10:15 PM
Members who have read this thread: 12
