Silver/chrome rear derailleur- Mtbr.com
Results 1 to 5 of 5
    Jun 2019
    New question here. Silver/chrome rear derailleur
    Hi! I'm looking to convert my early 1991 Karakoram to a 1x10 setup. Will something like a 10 speed 11-42 cassette fit? It's on Deore LX the moment.
    I want the derailleur to be chrome, dull chrome or "raw alu", not interested in "painted" silver. Does a thing exist? The Microshift R10 derailleur shows the look I'm after (but it doesn't have the range needed): https://www.microshift.com/en/product/rd-r47-rd-r47s/
    Reputation: iamkeith's Avatar
    Feb 2010
    I think you could safely use that derailleur with a 36t cog if that was enough. Maybe get a longer B screw. Woolftooth makes an extender link that will allow you to go even bigger, but that sort of "shifts" your range rather than increases it.
    Remember that you'll need shimano road shifters (or bar ends on pods) rather than shimano mtb shifters. 10 speed is when the later switched to Dynasys which has a different cable pull. Also, shorter pulley cages tend to work better for 1x setups. Since you don't need to wrap as much chain, they don't slap around as much.
    Otherwise, I think you're SOL on finding a proper, silver finish unfortunately.
    We still hang bike thieves in Wyoming [Pedal House]
    If that gt 7 or 8 speed? If it's 7 you'll need a new hub. Anything 9 speed is sure to work with 10 speed. 8 is compatible as well.
    If you're going 1x though you might as well get 10 speed Shimano slx or xt. No sense in running a half assed kit, looks are great but function is most important
    The derailleur you listed above doesn't have a clutch. That's one of the key features you'll want for a proper 1x setup. Clutch helps to keep the chain tight and aids in keeping the chain on the ring. Very important if you'll be hitting any bumpy trails. You might be able to get by without it but it's not something I'd consider as reliable or safe.
    83 Ritchey Everest
    88 Mountain Goat Whiskeytown Racer
    95 Bianchi Mega Tube ti
    2012 Ibis Mojo HD
    2015 Kona Process 153
    Jun 2019
    New question here.
    Quote Originally Posted by eshew View Post
    It's a 7 speed Deore LX. New hub, duly noted. Thanks.
    I found the Sram X0. (Partially) true chrome. Seems like a good alternative?Silver/chrome rear derailleur-35374_.jpg
    Wont go for that one.
    Quote Originally Posted by iamkeith View Post
    See above picture.
    Here's what I would do.
    That XO 10 speed rear deraileur (use anti seize when installing onto frame)
    X0 or X9 10 speed shifters (XO's are really nice)
    SRAM 10 speed chain
    Shimano XT or SLX 10 speed cassette
    Narrow wide ring in whatever size you want (In the correct BCD for your crank)
    New (or used) rear wheel with 9 speed+ hub (shimano style freehub, not SRAM Driver) FREE SHIP 48 STATES* MTB Wheelset PROMO SALE Vuelta ZeroLite Comp Aluminum Wheelset, Alloy Hub MTB Disc Brake Wheelsets
    83 Ritchey Everest
    2012 Ibis Mojo HD
  1. Replies: 14
    Last Post: 12-09-2011, 06:27 PM
  2. Silver brazing on top of chrome?
    By Walt in forum Frame Building
    Last Post: 10-25-2011, 08:01 AM
  3. rockshox recon silver tk silver question
    By bigturd in forum Shocks and Suspension
    Last Post: 03-24-2011, 07:36 PM
  4. Rockshox Recon silver R or silver TK?
    By seano26 in forum All Mountain
    Last Post: 03-01-2011, 10:16 PM
  5. Salsa Semi 29 silver - Please specify silver!
    By megalow maniac in forum 29er Bikes
    Last Post: 02-25-2011, 08:45 AM
Members who have read this thread: 33
