Salsa Ala Carte 1x9 conversion questions- Mtbr.com
Results 1 to 6 of 6
    Not sure this is the right forum but I'll try: I'm building up an '04 Salsa Ala Carte with its rigid fork and discs. I want to try it as a 1x9. Can I use my XT 750 crankset removing the small and large chainrings and then using my XTR 12 32 cassette and XTR 952 rear derailleur? Thanks!
    VRC Illuminati
    Reputation: Rumpfy's Avatar
    Definitely the wrong forum.
    -eric-
    http://www.rumpfy.com
    Relax. I'm a pro.
    Yes. Lose the front derailleur, install a bash ring and a device to keep the chain from falling to the inside, and you're set.
    I'm just messing with you
    Reputation: wv_bob's Avatar
    And shorten the chain
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    defender of bad taste
    Nov 2007
    If you're building from scratch a 1x8 might be a better way to go, and look for a chain ring with no ramps/pins - some DH rings are like this - if you get good tension in the chain you might get away with no chain retention devices.
    5 is the old new black; 6 is the new new black...
    Stokeless Asshat
    Reputation: jeff's Avatar
    What do you plan on using for shifting?
    Zip ties? Not on my bike!
    Want:
    650B rims or wheel set. 80's vintage 32 or 36 x 135mm
