replacement brass rods for syncros post head?- Mtbr.com
Results 1 to 17 of 17
    artistic...
    Reputation: colker1's Avatar
    I have a beautifull syncors rendered useles since the rod threads are stripped. I tried fitting thomsons rods but they are slightly bigger. Tried ebay etc.. Any clues? Those machined syncros posts are an icon of early nineties mtbs.
    WTB: Bomber Z2 1 1/8 steerer, in good to excellent shape OR bomber rebuild kit.
    Mtn Biker Machinist
    Reputation: 1 cog frog's Avatar
    Dec 2004
    Pics of the needed part?
    Practice Gratitude
    Reputation: Plusti's Avatar
    Good job! Maybe a long shot?
    This may be a long shot but have you already contacted Syncros directly? They offer replacement parts. I'm doubtful if they have back stock from 30 years ago but maybe they can tell you the manufacture or part numbers on those seat post pieces?
    https://help.syncros.com/hc/en-us/ar...-from-Syncros-
    I do also recall seeing those barrel nut rods at local hardware stores like "Lowe's Hardware":
    https://www.lowes.com/pl/Barrel-nuts...are/4294710819
    Hope this helps some,
    Jason
    “It never gets easier, you just get faster.” ~ Greg LeMond
    2012 Specialized Carve
    artistic...
    Quote Originally Posted by 1 cog frog View Post
    I will take the pics but i can describe as well: itīs a rod thatīs insert on the top part which presses against the saddle rails and the cam. Two bolts attach on the rods.
    Thomson has similar rods but spec is slightly bigger.
    artistic...
    Quote Originally Posted by Plusti View Post
    Jason
    Syncros tell me i should go through their dealers but there are no syncros dealers around. I saw those barrel nuts at Lowe but there is no way to tell if the right width; those things should fit tight inside the top cam. Best bet is finding a busted Syncros post and canibalize the part.
    No known cure
    Reputation: Vader's Avatar
    Do you mean this threaded rod?
    https://www.bikethomson.com/product/sph001/
    BTW, the entire saddle rail assembly from Thomson is the exact radius as Syncros and they're interchangable.
    Ripping trails and tipping ales
    artistic...
    Quote Originally Posted by Vader View Post
    Thomsonīs rod is slightly bigger and does not fit inside Syncros cam. I could take the whole thomson top cam but rather keeo it all syncros.
    No known cure
    Quote Originally Posted by colker1 View Post
    Thomson also has hardware for their dropper post which aren't compatible with the Elite or Masterpiece post. In the pic they look like a smaller diameter. Maybe shoot them an email and see if they're close to the Syncros parts.
    artistic...
    I tried fitting them to the Syncros and no go. I would have to shave material and i donīt have machines to do it.
    Reputation: ladljon's Avatar
    Why not just get a tap or die, to change, clean threads.....
    Tread killer....
    artistic...
    Quote Originally Posted by ladljon View Post
    I will try that route.
    No known cure
    The dimentions from bikepro's site.
    "A hole is drilled through the arms that will accommodate a brass rod. The rod is .58" long and .3" in diameter with a hole drilled through the middle of its side, tapped with threads."
    Mtn Biker Machinist
    Dec 2004
    Does it list thread size by chance?
    artistic...
    If only Thomson used the same rods: theirs is a fraction of a milimeter bigger. Thread seems to be the same but size of the rod is different
    No known cure
    LOL. You had to ask. The BikePro site is deep with info.
    "The bolts are made of cadmium plated steel with 5mm x 1mm threads, are 35mm long have a 4mm hex fitting and weigh 6 grams each."
    Mtn Biker Machinist
    Dec 2004
    Dang! It’s so satisfying to my machinist brain!
    Mtn Biker Machinist
    Dec 2004
    BikePro either has a typo, or Syncros chose the M5x1 “special” thread, which is not very common. Most metric tap sets don’t even have that thread size. M5x.8 is the common size in 5mm.
  1. Flux coated rods
    By bikecycology in forum Frame Building
    Last Post: 02-23-2014, 11:45 PM
  2. 2003 Mazda Protege5 with Rocky Mount Tie Rods
    By Chris V. in forum Cars and Bike Racks
    Last Post: 12-14-2011, 05:02 PM
  3. Ready for some Hot Rods' ing
    By J Ro in forum Vintage, Retro, Classic
    Last Post: 01-22-2008, 09:58 AM
  4. All Mtn With Z1 Rods???
    By TONYACCURSO in forum Turner
    Last Post: 05-20-2005, 09:56 AM
  5. Odyssey Straddle Rods
    By uphiller in forum Vintage, Retro, Classic
    Last Post: 12-18-2004, 12:27 AM
Members who have read this thread: 25
