Recommendations for vintage MTB's for single-speed conversion- Mtbr.com
Results 1 to 23 of 23
    Reputation: corwin1968's Avatar
    Oct 2011
    I've wanted a dedicated single-speed for several years now and I'm going to start watching for that perfect frame (which may not exist). I want a sporty-geometry mountain bike with semi-forward facing dropouts.
    The 90's Bridgestone MB's have perfect geometry but vertical drops. It seems that some of the early 90's Specialized Stumpjumpers/Rockhoppers might have had the dropouts I want but I don't know about their geometry.
    What I don't want is early, slack MTB geometry. Have one of those and it's completely unsuitable for my purposes.
    Any recommendations on old MTB's that fit these criteria?
    Sergeant Spandex
    Reputation: lewisfoto's Avatar
    Nov 2013
    I Have a 1990 stumjumper comp currently set up as a single speed. I rode it for years and was very happy with the performance. Right now it is kind of ugly with mismatched tires and whatnot, but here is a pic anyway...
    Attached Thumbnails Attached Thumbnails Recommendations for vintage MTB's for single-speed conversion-91-stumpjumper-1-web.jpg
    Recommendations for vintage MTB's for single-speed conversion-91-stumpjumper-2-web.jpg
    Reputation: proto2000's Avatar
    If you can get your hands on a steel Ibis Mojo that should put a smile on your face for sure. Light weight, nice geometry and it has a handjob.
    Too many bikes, and just enough time to ride them.
    The Crazy Cat Lady of VRC
    Reputation: eastcoaststeve's Avatar
    I have a pile of vintage SS rides....Klein, Bontrager, Psyclone, etc...they're all a blast.
    If you're not hung up on steel, grab an early Klein Attitude/Rascal with rear facing dropouts and enjoy.
    Steve
    Mid 90's (I think) Diamondback Apex with TT lite tubing. Bonus was magic ratio - 32:19 (I'm a wuss and it's hilly in socal).
    Phobia of petting zoos.
    Vertical dropouts and a White Industries eccentric rear hub. That opens up the options.
    Unless of course you already have wheels you really want to use.
    Salsa Ala Carte from pretty much any era is an option too. Kona's steel offerings are popular options.
    I had a Mountain Cycle Moho for a while (until the cracks started appearing). It was bloody light. Then a Diamond Back WCF until it copped a rock into the downtube, and now the rigid single speed is a later model Soma Groove.
    Grumps
    Oct 2011
    There are a couple of Rockhoppers on E-bay right now, one a base model and one a Comp model. These two bikes appear to have different dropouts. The Comp's look more vertical but even the base model's dropouts look really short. Would the base model's dropouts be long enough to tension a SS chain? I assume the Comp's wouldn't work at all without a tensioner, is that corrrect?
    Specialized Rockhopper Frame and Fork Single Speed Fixie Horizontal Dropouts | eBay
    Vintage 1992 Specialized Rockhopper "Comp" Mountain Bike Custom Butted Steel | eBay
    Sergeant Spandex
    Nov 2013
    The drops on the base model in your link are the same as on my Stumpjumper, and are long enough to tension a chain.
    Oct 2011
    Well, I picked up that Rockhopper frameset with a few components on Ebay and I should have it within a week. The only other things I need to buy are a spacer kit/cog and some single-ring crank bolts. This will be my minimal expense proof of concept build and if I really, really like it, I'll get it powdercoated and color-coded (ie, all silver or black components) and put some higher performance tires on it. From what I've seen of Stumpjumpers, framesets are too rare and too expensive to justify seeking one of those. Would be nice to have that really light prestige tubing but if I can end up with a SS bike that's in the mid-20 lb range, I'll be thrilled.
    Sergeant Spandex
    Nov 2013
    This is the greatness of that particular frame, you can do the single speed conversion with very few special parts. At first I used the XT cassette hub with simple spacers and a lone cog from a Shimano cassette. Also gave a wide range of options for a perfect chain line.
    Completely agree with Lewisfoto, I have that same frame (gifted to me via a very gracious fellow VRCer) and it is amazing for this. All I did was take a XC Pro crankset and make it is a single ring and then ran spacers on the freehub body with a single cog, works like a charm. Never have weighed it but it is quite likely low 20s even with a brooks on it...... also you would be surprised how cheap you can pick up a Stumpie like these.....
    Oct 2011
    I'll continue to watch E-bay and the pawn shops but in two years all I've found locally is lower level Treks.
    I have no idea how stout the Rockhopper is but if it ends up weighing 25-27 lbs, I'll be thrilled.
    whoa
    Jan 2005
    You could look for a Pace, OR Toad, or Giant Cadex with replacable aluminium dropouts.
    I had a Pace and a Toad, before i switched to a modern Slingshot.
    https://www.flickr.com/photos/oldsch...ng/9299234288/
    whoa
    Jan 2005
    And not to forget Grove Innovations Hard Core and X.
    https://www.flickr.com/photos/oldsch...ng/13377547353
    Reputation: Woodpuppy's Avatar
    May 2014
    I scored a '97 Ibis Mojo frame off epay and a wheel set with king front & white industries eccentric rear. The only part I'm lacking now is the right length BB. My '98 mojo with a Marzocchi fork is ~25 lbs, or was before I installed a Brooks.
    Enjoy!
    'Tis better to bail and not to hurt, than not to bail and eat much dirt!
    -unknown
    Oct 2011
    I got the Rockhopper up and running a few days ago. There was a learning curve for installing the BB and cranks and then using a chain tool but I got it figured out. I despise messing with traditional cantilevers so I'm waiting for some V-brakes to put on it. The current gearing combined with my chainstay length puts the rear wheel at the very front of the dropouts....further forward than I'm comfortable with. I had the LBS order me a half-link and I will pick that up today and hopefully it won't make the chain too long. This bike has very short dropouts so if that doesn't work then I guess I'll have to switch the cog and try that.
    From my limited time riding this thing, it's living up to my expectations. It's just a blast to ride around the neighborhood and I have had no desire to ride my good multi-speed 700c bike.
    Recommendations for vintage MTB's for single-speed conversion-0000000000000-rockhopper-4-.jpg
    Don't worry about the half link just yet. Assuming it's a new chain, it will settle in and stretch a little first, allowing you to pull the wheel back in the drops a little.
    I hear you, having the axle at the very front of the drops results in a little voice telling me that out of saddle efforts are not a good idea. Use a bolt up axle or at least use a Shimano quick release skewer, they just hold better than the external cam type.
    If you swap to v-brakes, make sure your levers are compatible, v brake levers and centre pull canti levers are different.
    Grumps
    whoa
    Jan 2005
    The most important Singlespeed part, a wide bar!
    And a better picture of my Pace as Singlespeed.
    Reputation: vindiggitydog's Avatar
    Found this old Schwinn Mesa....
    This is a super fun ride...coaster brake included:-)
    Attached Thumbnails Attached Thumbnails Recommendations for vintage MTB's for single-speed conversion-photo.jpg
    Sergeant Spandex
    Nov 2013
    Quote Originally Posted by vindiggitydog View Post
    I had a coaster brake single speed (coastie) for a while and really had a good time spinning around the hood. Clean looking bike too.
    May 2020
    Frane
    where i find this frame for sell? What type frame this is are?
    May 2020
    May 2020
  1. help with a single speed conversion
    By 28dayslater in forum Singlespeed
    Last Post: 07-28-2013, 07:04 AM
  2. single speed conversion help
    By 94hardtail in forum Singlespeed
    Last Post: 07-11-2013, 04:43 AM
  3. Single speed conversion
    By mtrap in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-15-2011, 11:33 PM
  4. Single Speed Conversion
    By naptownryder in forum Beginner's Corner
    Last Post: 08-13-2011, 04:20 PM
  5. Single Speed Conversion
    By arkon11 in forum Urban/DJ/Park
    Last Post: 05-20-2011, 12:49 PM
Members who have read this thread: 16
