Old Specialized Rockhopper help- Mtbr.com
Results 1 to 5 of 5
    Im trying to identify the the front fork on the wife's old Specialized Rockhopper FS (guessing a late 90's). I cannot locate a serial number anywhere on the fork. It is oil filled (leaking oil and reason for this post). It has the smooth plastic caps on top of each shock, non adjustable preload. There are snap rings under the boots that appear to hold the shock tubes in place. I am thinking it is not serviceable. If it helps it is a threaded steer tube.
    If I end up having to replace it, what should I get? Looking to get something inexpensive as she mainly just rides smooth trails.
    Jan 2017
    If the name on your suspension fork is Specialized Future Shock, it is a re-branded Rock Shox , either a mag 10, 20, or 21, and you can get oil seals for them here:
    https://www.enduroforkseals.com/prod...ic-fork-seals/
    If you have to get a new fork get one with the same travel and close axle to crown measurement or you will end up with a chopper looking bike, with bad handling. I had a 94 stumpjumper that the suspension fork died on, and ended up have to go with a rigid fork to match the a/c measurment.
    Quote Originally Posted by awilli View Post
    Do you know how to remove the existing seals? I have gotten the fork apart to were each side's shock is out. Is the inside tube removable? Or to you just remove the seals and slide them out over the tubes? I tried searching for a how to video with no luck. Plenty of videos for other style shocks just not mine.
    Reputation: Vespasianus's Avatar
    Might need to take a pic. Most of the rockhoppers came with just elastomer or MCU forks - Rock shock Quad 5, Indy or Manitou SX forks or even lower.
    On MTBR, the reputation is infamous.
    Jan 2017
    Quote Originally Posted by Kallen425 View Post
    I got mine apart with air pressure, but this may have been a different shock than you have. As Vespasianus suggested, you should post a pic and maybe someone can identify your shock and head you in the right direction.
  1. Specialized Rockhopper Comp vs Rockhopper Expert?
    By Tstaw13 in forum 29er Bikes
    Last Post: 04-27-2017, 08:44 AM
  2. 2017 Specialized Rockhopper vs Rockhopper Sport
    By sahil04 in forum 29er Bikes
    Last Post: 08-25-2016, 08:19 AM
  3. Specialized Rockhopper or Rockhopper comp
    By locomonkeyz13 in forum General Discussion
    Last Post: 06-15-2013, 10:03 AM
  4. 2010 Specialized Rockhopper Comp vs 2011 Rockhopper
    By FL_rider in forum Beginner's Corner
    Last Post: 06-28-2011, 02:38 PM
  5. Old Specialized Rockhopper... any idea how old?
    By plasticspaceman in forum Vintage, Retro, Classic
    Last Post: 07-28-2006, 10:43 AM
Members who have read this thread: 39
