Ok, its not old production but it is old geometry/design...- Mtbr.com
Results 1 to 1 of 1
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    The E-stay hardtails Ediscount's been listing on ebay are a copy of the old Rocky Mountain Cirrus frame. I suspect that the manufacturer bought the old jigs and production plans for the Cirrus (the frames were made in Japan) and used them for their own model. The originals used a simple clearcoat over bare aluminium, with a 7005T6 tubeset. The new version is painted (they have red ones and gunmetal blue ones on ebay, as low as $39.99US) with a 6061T6 tubeset. Frame weights are virtually identical (the ones I got from ebay, listed as a 17" but its really a 19", are 5 Ibs 6.8oz) and the toptube is relatively short (22.5" on a 19" seattube), just like an old Cirrus. Also the frame has a tapped screw hole at the base of the seattube for running a pulley to use a bottom pull front derailleur, just like a Cirrus had. Same small welded cross brace in the lower stays, behind the seattube, same shorter CS length (about 16.5", not as bad as the Experience which was 15.9").
  1. Replies: 6
    Last Post: 01-31-2004, 06:57 AM
  2. is X-5 still in production?
    By yellowwducky in forum Ventana
    Last Post: 01-21-2004, 09:06 PM
  3. Roll Call.. Post 'em if you got 'em~!
    By Snowmonkey in forum 29er Bikes
    Last Post: 01-15-2004, 11:37 PM
