Longer A2C Fork on Early MTBs (1990-1995)- Mtbr.com
Results 1 to 11 of 11
    Formerly PaintPeelinPbody
    Reputation: PHeller's Avatar
    Dec 2012
    I've got a 1990 Marin. 385ish a2c original rigid fork.
    When I search for pictures of this bike, I see quite a few examples in the 1990-1992 years of these frames with early suspension forks - 400-410 A2C. Including Marin themselves!
    Longer A2C Fork on Early MTBs (1990-1995)-marin-bikes-jvanhorn-7781-780x520.jpg
    I don't want a suspension fork this bike, but what I do want is more tire clearance - ie the ability to run 26x2.8 tires.
    Luckily, the new obsession of hipsters (of which I'm one) for small wheeled bikes has Crust making two suitable forks - the Evasion 65mm offset fork (400m a2c) and the segmented fork (408mm a2c).
    Anybody know of any other, cheaper (under $100) forks that'll fit 26x2.8 while being around 400mm a2c?
    Work - Utility GIS Analyst
    Party - 2019 Guerrilla Gravity Revved Trail Pistol Sz 3
    -bustin punks
    Reputation: fatchanceti's Avatar
    Jan 2005
    I ran a 27.5x 2.3 tire on one of the 26er 410mm a-c Kona/Carver unicrown forks that you can grab for around $90 at bikeman.com
    2.8" might be pushing it though - depending on rim width.
    No known cure
    Reputation: Vader's Avatar
    Here's the original fork. The stem will be the same matching green. I no longer have mine so I can't check the serial number or A2C.
    Attached Thumbnails Attached Thumbnails Longer A2C Fork on Early MTBs (1990-1995)-marin001.jpg
    Ripping trails and tipping ales
    Bikes in jeans
    Reputation: jestep's Avatar
    Are you switching to threadless? Also aren't these 1" steerer? I don't think there's any way you're going to find a threaded fork that fits 2.8. You might be able to get something to clear a 2.3 - 2.35 on there, but I don't think something threaded that clears more than that exists. Other option would be custom, but that's obviously going to be expensive.
    WTB: Med Bontrager Ti Lite, PM Me...
    Dec 2012
    I think these are 1 1/8th, although my 1" quill stem adapter works fine. I think it's because the outside diameter is 1 1/8th and the internal diameter is 1". Honestly not 100% sure though. Maybe it's just a case of quill adapters being not so particular.
    I could easily switch to threadless - I've got spare headset.
    -bustin punks
    Jan 2005
    I have a 1" fork that will fit a 2.8 tire (pretty sure) but it's unthreaded. The axle to crown is also a bit long at 425mm I believe. Carbon legs, alu crown, chromo steerer. Not vintage at all, but would get the job done - and I imagine the wall thickness on the steerer is thick enough to be threaded. It's also disc only - but I think you can find versions of it with canti posts too. Anyway, I could get it to you for under a hundred easily if you think it might work.
    Dec 2012
    In case anyone cares, the Surly Lowside fork is now my main interest.
    It's 420mm a2c, which is about comparable to the RS1 and other early suspension forks. It's 1-1/8th straight steerer, as well. I've got an old threadless headset I can use.
    It's disc, too.
    I'm going to get real crazy and run it with a 275x3 tire, which should lift my front a good deal, another 20mm over my current 26x2.5 tire. That'd be total about 50mm of front end lift. The RS1 had 60mm of travel, but at sag but sat much lower.
    Luckily, my intention is not run this setup by itself, but combined with a Xtracycle Freeradical Leap conversion. Usually one of the negative results of such conversion is an overly low BB, so this, combined with another 275x3 in the back should lift the BB to a satisfactory level for off-road adventures.
    artistic...
    Reputation: colker1's Avatar
    Quote Originally Posted by PHeller View Post
    It's disc, too.
    You canīt fit a 27.5 x 3in in the back. My advice: buy another frame or ride this under itīs limitations. Find an old surly 1x1 or get a chinese carbon hardtail. Otherwise you will spend a lot of money and say good bye to your bikeīs handling quality.
    WTB: Bomber Z2 1 1/8 steerer, in good to excellent shape OR bomber rebuild kit.
    artistic...
    Quote Originally Posted by fatchanceti View Post
    I know the fork you mention.. I am looking for something just like it but w/1 1 /8 steerer and canti posts. I would like a Vicious cycles but they are bit too much $$ for what i have in mind
    artistic...
    Quote Originally Posted by jestep View Post
    1 1/8 steerer.
    Dec 2012
    Quote Originally Posted by colker1 View Post
    You missed it - I'm doing a cargo bike conversion.
    Xtracycle Leap will fit a 275x3 (or fat, or 29+) in the back.
    If I were to run 26x2.5 front/rear with the cargo bike conversion, my BB would be low. Running both ends at 275 should rectify that.
    I also am very much against the idea of buying a new frame everytime I want a bike to fit a very small niche. I have a personal attachment to this frame, so it's not going anywhere, but I'd feel bad about not using it. This provides me an opportunity to both use the frame and fill the role of a kid hauler. I've talked with a quite Leap owners and none of them have anything bad to say about the conversion kits.
    In my case, despite the Leap kit costing me $600, I can have the 275x3 cargo conversion rolling for $800.
  1. 1995 Mountain Cycles San Andreas....I think it's a 1995.
    By mattkock in forum Vintage, Retro, Classic
    Last Post: 08-09-2017, 03:27 PM
  2. So I picked up a couple of 1990(?) mtbs this week...
    By w00t! in forum Vintage, Retro, Classic
    Last Post: 04-06-2013, 10:13 PM
  3. Moto guys take over MTBs --- KTM MTBs
    By NEPMTBA in forum Pennsylvania
    Last Post: 08-16-2011, 11:21 PM
  4. 1990 Doug Bradbury Manitou w/early fork
    By Fillet-brazed in forum Vintage, Retro, Classic
    Last Post: 06-16-2011, 09:37 PM
  5. PIKE A2C vs. Van 32 A2C
    By ddraewwg in forum Shocks and Suspension
    Last Post: 06-13-2008, 02:21 PM
Members who have read this thread: 24
