hey GM, GT question...or anyone else- Mtbr.com
Results 1 to 29 of 29
    illuminaughty
    Reputation: da'HOOV's Avatar
    Jan 2009
    I just picked up (read...was given) a steel GT frame, stripped of paint but it used to be Sky Blue, flat GT logo on end of top tube, internal routing for rear seatstay mounted U-brake, 1 1/8" rigid fork has Canti mounts, has a GT stem like the
    'flippable" one but is not "flippable". I think it's a Karakorum? 90ish? serial number starts with T9002...any ideas? I looked thru the GT thread with no luck....thanx
    pics to follow if needed..
    Reputation: Linoleum's Avatar
    Stan - Search the 'Official GT" thread in the vintage forum. Padre posted the exact bike you're describing. Blue, internal routing, steel frame, flat (albiet angled) GT stamped.
    Rich
    Reputation: gm1230126's Avatar
    Pics would help. 90-92 vintage if 1-1/8". Color sounds like maybe a Tequesta.
    Needed: 26.8mm XTR seatpost, blue GT/Grundig Jersey.
    illuminaughty
    Jan 2009
    Quote Originally Posted by Linoleum
    Rich
    thanx but not the one, this one's a traditional triple triangle and more sky iin the blue color (lighter)
    Reputation: laffeaux's Avatar
    Look at the Tequesta in this catalog:
    http://www.mtb-kataloge.de/Bikekataloge/PDF/GT/1990.pdf
    Each bicycle owned exponentially increases the probability that none is working correctly.
    Quote Originally Posted by da'HOOV
    Doh! I didn't read the 1 1/8th fork. Yeah, it'd be newer than the one I referenced.
    illuminaughty
    Jan 2009
    nope,
    Quote Originally Posted by laffeaux
    It is/was a solid blue, no fades, no spiderwebbing just blue
    Pic please...
    Glorified Hybrid Owner
    Dec 2005
    GT Ricochet???
    slow
    Reputation: sgltrak's Avatar
    Feb 2005
    I am going to second the '90 Tequesta pictured on p.7 in that catalog. On some of those Nimbus paint jobs, the white was hardly noticeable, making the bike appear to be a solid powder or sky blue.
    edit: Upon examination of the photographic evidence presented hereafter, I retract the above statement.
    defender of bad taste
    Nov 2007
    1988/1989 Timberline.
    Assuming the GT logo on the end-cap looks like this:
    illuminaughty
    Jan 2009
    double post
    oops......thanx again
    illuminaughty
    Jan 2009
    here's some pics
    maybe these will help. The dropouts have a "C" on them, note the double "bridges" on the seatstays, flush brazed cable inlet on top tube, ovalized at back end of top tube and bottom of seat tube......thanx again
    Attached Thumbnails Attached Thumbnails hey GM, GT question...or anyone else-gt1.jpg
    1989 Karakoram K2, or maybe an 89 Avalanche in Arctic Snowstorm. Was it a solid colored paint or did it have specks in it? Could also be a 91 Timberline in Deep Teal...1" or 1-1/8" head tube?
    Attached Thumbnails Attached Thumbnails hey GM, GT question...or anyone else-gt-news-07.jpg
    illuminaughty
    Jan 2009
    so what does the K2 stand for? and the "C" on the dropouts? thanx
    Dec 2005
    Quote Originally Posted by gm1230126
    It looks like a later stem.
    It looks just like the '90 Tequesta, but with solid paint. http://www.mtb-kataloge.de/Bikekataloge/PDF/GT/1990.pdf
    So it may be another model or a 91 or so...
    Dec 2005
    Quote Originally Posted by mechagouki
    BTW, I found a stack of those sticker at my local shop (along with a lot of GT BMX stuff).
    Dec 2005
    Here you go...look at page 27.
    1993 Tequesta (blue, but not sky blue) with correct stem.
    http://www.mtb-kataloge.de/Bikekatal.../GT/1993-2.pdf
    illuminaughty
    Jan 2009
    Quote Originally Posted by rockhound
    nope, this one's earlier...with a U-Brake.
    illuminaughty
    Jan 2009
    I got it exactly as pictured so I don't know about the color, the stem and fork look solid color to me....1 1/8" headtube..
    http://en.wikipedia.org/wiki/Karakoram
    I believe the C on the dropout is just a labeling that refers to the angle of the dropout legs but am not totally sure..
    Dec 2005
    No...it's not a Tequesta. Tequesta's had welded tabs at the seat clamp area.....Hoov's frame does not.
    Dec 2005
    Yeah, I thought of that after the fact.
    illuminaughty
    Jan 2009
    duh funny how sometimes we look too deeply for an answer or reason...thanx
    illuminaughty
    Jan 2009
    for now I'm going with the Karakoram (or maybe Avalanche?) answer....if any of you have an '89 or '90 model would you share your serial # so I can try to narrow it down? If you want to keep it private, PM me...thanx Stan
    Dec 2005
    The Avalanche and the Karakoram in the pics have different stems than yours does.
    Stan what's the month and year date stamped on the fork steer tube?? What is stamped on the fork steer tube for material CM/CM or HT/CM...the answer to that would decide if it's a Tequesta.
    illuminaughty
    Jan 2009
    It was hard to see thru thr paint but it says.......
    top line "1989 CR-MO"
    next line "K2 25.4 X 30" (theres a sideways 0 after the 30)
    dropouts say "spinner"
    so I'm guessing 1989 Karakorum K2.....gee, I think somebody said that .
