help with spinergy spox freehub removal- Mtbr.com
Results 1 to 3 of 3
    Apr 2020
    Hi all!
    I have some old wheels, that I'm trying to rebuild, ordered new bearings and trying to figure out how to remove the free hub. The normal 10mm hex key is too small. If I look inside I can see something, but it looks like it has more flat spots than a normal hex.
    However inside the free hub it has two notches.
    Any suggestions on how to remove the free hub? Spinergy didn't know and just said these are 20+ years old.... Rim brakes.
    Attached Thumbnails Attached Thumbnails help with spinergy spox freehub removal-unnamed-5.jpg
    Hybrid Leftys aren't real Moderator
    Feb 2005
    I thought they were a Shimano FHB, so, 1o, through the front side.
    Plainly not, so I'd then pivot to a 12 mm, coming in from the back side.
    If so, put the wrench in a bench vice, long end pointing up, and put the wheel onto it.
    Spin wheel to remove...
    Cannondale Lefty and HeadShock servicing, wheel building, etc...
    www.mendoncyclesmith.com
    Apr 2020
    Thank you for this.
    Just to confirm with the free hub pointed up. Clockwise or counter-clockwise to remove?
  1. Spinergy Xyclone disc / freehub issue
    By jackthejedi in forum Wheels and Tires
    Last Post: 04-22-2013, 01:07 PM
  2. Spinergy spox 32 spoke rim
    By forrestmiller in forum Wheels and Tires
    Last Post: 01-17-2011, 11:38 AM
  3. spinergy spox spokes where can i find 5?
    By Harryonaspot in forum Wheels and Tires
    Last Post: 11-06-2007, 06:58 PM
  4. Old Spinergy Spox Overhaul
    By mathias in forum Tooltime
    Last Post: 06-03-2007, 09:01 PM
  5. Spinergy Spox Wheels: Run away?
    By kapusta in forum Wheels and Tires
    Last Post: 05-08-2004, 08:21 PM
Members who have read this thread: 19
