help me ID this klein- Mtbr.com
Results 1 to 7 of 7
    it's stripped of paint/decals, so i can't tell what it is.
    -Serial number 00885da located on non-drive dropout, not BB shell.
    -It's got a traditional rear derailleur hanger (not rear entry dropout like my pulses).
    -The cable routing is top tube (not internal).
    -1-1/8 Steerer Tube
    -Seller thinks it's an early 90's Rascal.
    none of the other klein serial number threads i've been able to find seem to help...
    thanks!
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    Photo?
    Not a Rascal
    Not early 90's (if it were a Rascal)
    and not a Klein if it has a 1 1/8 steerer and dropout serial number
    Quote Originally Posted by Shayne
    Not a Rascal
    thanks. pics added to first post. weird serial number though... the welds look kleinish (maybe), but i don't see box section chainstays near the BB shell, and it has a cross-piece between the chainstays just behind the BB shell, which i didn't think kleins had...
    seller also says he thinks it was built by Caloi for Klein, but i didn't think that ever happened. maybe it's just a caloi... looks like this one (from ffb). if so, are these good frames? i've heard/read very little about caloi:
    Klein's also had the internal cable guides which that frame doesn't
    - Jeff
    ____________________________
    '97 Adroit, '96 Adroit, two '93 Attitudes & '90 Attitude
    Reputation: gmats's Avatar
    Apr 2005
    Kleins of that vintage didn't have screw in BB? I thought they were all pressed in. I know the 80's vintages like my Pinnacle was press fit.
    Quote Originally Posted by s4gobabygo
    -1-1/8 Steerer Tube
    thanks!
    Not a Klein at all. Dead giveaways are the dropouts, cable routing, and standard bottom bracket.
    Dimitri in NYC
    04 Jamis Dragon
    01 Jamis Dakar Expert
    90 Klein Pinnacle (Sea and Sky repaint)
    Reputation: ShamusWave's Avatar
    Only difference for -97 Pulse comp is rear dropouts.
    It has 1 1/8" headset, normal bb and cable routing on toptube.
